Lockers - ARB or Electric?
Started by EricCartman, July 03, 2007, 09:59:12 AM
EricCartman
Hi All,
I've come to the point where I am thinking about doing lockers...  I'm pretty sure I want to get a selectable locker.  So that leaves pretty much ARB or Toyota E-lockers.
There are several things I like about the Toyota e-lockers...  such as being factory parts and they can be manually operated if needed.  The part that I don't like so much - is the welding/drilling/tapping to my existing housing to get these to fit.
The ARBs seems quite nice too - since they are fast to engauge and I don't have to do any modification to the axle housings.  The only thing that makes me a little leary is that this is controlled by air.  I would think eventually a seal could fail and that would be the end of it.  I have not read any posts about this happening... but I suppose it could.
My plan was to buy the complete 3rd members from Marlin - and do the install myself.  This can be easily done with the ARB option - but the e-locker would be a bit more difficult.  I would have to pull the axle housing and get the machine work done at a competent shop.
What do you all think?  Would it be worth the hassle to pull the axle housings out to get the machine work done and a shop so that I could have e-lockers?
Thanks,
Cartman
red
really it comes down to preference. the arb company has not had an actual locker fail, but if you run the lines incorrectly you can have a line fail (run it too close to the exhaust, run it so the line can bind up/break, etc...). but, with the arb you also get a compressor so you can air up your tires after a trail ride.
e locker is more of a pain to set up as you mentioned but doesnt have the potential problems of installing the lines incorrectly.
read and comment :whip:
USAF EOD tech
Volcom
I think both are great lockers.  What I don't like about the E locker is the engagement time.  Sometimes they engage right away, other times it can take 5-10 seconds.  With the ARB, it's instant.  My brother has been running ARB's F&R in his YJ for over 2 years, no problems at all.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
~tc~
99.99999% of the problems with ARB's are installation related.
I priced out both options, and if you want any degree of on-board air the ARB route is cheaper.
'93 4Runner, V6/MT ARB's, armor, 33's, no lift!
President, CO Chapter TTORA www.cottora.org
OOPS
I prefer ARB's because of how fast the lockup compared to the e-locker. Either one are good. The two problems I have had in ten years of running them both have been installer error.
As far as using the ARB compressor as OBA, I would not do it. It wearsthe compressor out prematurely. First five years I had mine in I used it and I had to rebuild the pump part. Cost was only thirty dollars  for a complete kit but the bad part was it started leaking bad on a Con run.
TurtleTappers91
The ARB is cool because you can lock it up on the fly. It works well. The mini compressors are nice too, pretty reliable...
I have had two air line breaks, I think the blue plastic air hose is the weak link, I'v seen some beefy brake line style replacement hose for sale, but it is big $$$
OOPS
Quote from: TurtleTappers91 on July 04, 2007, 07:56:16 PM
I have been running the same blue line on the rear for ten years.
TurtleTappers91
The air lines can snag tree branches and crap when bushwackin'
It all depends on what your gonna do with it I guess... :twocents:
EricCartman
Cool... thanks for all the input.  It sounds like either way is good will be just as good.  Now I just need to scratch up some coin. :)
46&2
Quote from: ~tc~ on July 03, 2007, 05:52:25 PM
X2. I am going to go with an ARB when i can afford it. Wanted toyota E lockers but a few people have told me they fried theirs going through a lot of deep water repeatedly. where I live there is no end to the deep water so i cant have a locker that may potentialy get disabled by moisture.
Rockcrawlintoy
Quote from: TurtleTappers91 on July 04, 2007, 11:00:15 PM
if u run the lines correctly you wont have this problem also u can use the heavy duty air lines which are much better.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
