Door limiter~help!!
Started by Cheesemaker, July 02, 2007, 01:49:58 PM
Cheesemaker
The door limiter (I don't know what it's actually called) is broke off.  It looks like it was a clean break!
What can I do to fix this?  Get a new piece that goes into the cab structure and bolt or pop-rivet it in?  Help!?  I've got the slider guts from a donor door.  How has anybody fixed this or done repairs to remedy this problem.  I just need the bracket that goes into the hole you see, or how did you fix yours!  Please post any ideas.  I just don't want the door just wildly flinging around!   :cheese:
i currently don't have those installed, and the hinges stop it from going anywhere.....
just looked at it, you don't have access to it.. except maybe from a few inches above it from the inside of the truck, if you remove the entire dash, or from the bottom of the cab in a very small hole.....
if you decided that you still wnat to have it, looks like a pop rivit will be the best, or nut and bolt.....
it looks spot welded OE and thats probably what caused it to snap off over time
Cheesemaker
Thanks Jim, but I would like to get something on there, due to we get alot of strong winds around here, and I just don't want the doors slamming around!  The hinges were fubar'd and I got lucky and the spare doors I bought have them!  I'm not anal, but I just want things to work like they are supposed to!
Right now, I'm curious on how others have fixed this problem!
DTB
i would cut the section out and replace it with a new one if u have access to a scrap truck..weld it in..if not just cut a piece of plate, cut a hold in the middle and weldit in. if that makes sense
Duffil
put the stocker on there and tack it.
