Author Topic: Part # Thread  (Read 3478 times)
AR80Toy
  • Turtle Points: -2
  • Male Posts: 319
  • Member since Mar '06
Part # Thread
« on: Jun 27, 2007, 08:22:12 PM »
I'm starting this thread because I know how hard it is finding part #'s , if anyone has any please feel free to post .
79-81 OEM Part #'s
Fuel Sending Gage = 83320-39176
Shift Lever Bushing = 33548-31010
Shift Lever Cap  = 33554-30012
Shift Lever Spring = 90502-26001
Shift Lever Seat = 33505-35020
« Last Edit: Jun 27, 2007, 08:32:21 PM by AR81Toy »
1983 Toyota 4-Banger Completely "Stock" For now ......HeHe
AR80Toy [OP]
  • Turtle Points: -2
  • Male Posts: 319
Re: Part # Thread
« Reply #1 on: Jun 27, 2007, 08:39:18 PM »
ENGINE RELATED
22R
gas tank pickup tube assy (longbed tank) 77203-35141 $26
engine insulator (t-case mount) ’83 12371-38020 $85
NOTE: The insulator/mounts vary through the years. They look similar, but are different.
22R rebuild gasket set (pre 8/84) - 04111-35022
22R oil pump O-ring - 15188-38030 $9.95
22R front crank seal - 90311-45014
22R oil pan gasket - 12151-35010
22R/RE idler pulley bearing - 90099-10091 $6.95 - or IR Torrington 6204PP, SKF 6204-RSJ, NSK 6204V, CR (Chicago Rawhide) 6204-2RSJ
22R/RE A/C idler pulley bearing - SKF/CR 6203-2RSJ $6.95
Crankshaft Oil Seal (Rear main seal) - 9031180010 $26.58
1986-1995 In-Line4
22Rxx cam rocker spacers 90561-16005
valve cover gasket/seal set - FelPro VS50357R $15.00 (should fit 22RE too)
- - Or separately from dealer:
gasket - 11213-35010
seals (for thru-bolts) 90210-08026
semi-circular plug - 11183-38010
PVC grommet - 90480-18180 $ 2.14
Carb components for Aisin, dealer only (Feb, 2006)
Float assembly 21209-37041 approx $26
Jet, first main 90999-41116 approx $8
Jet, second main 21253-35410 approx $8
Jet, S/A, slow 21205-35410 approx $10
Spacer, carb to intake manifold 21912-35050 approx $20
FOR LATE 22R – (after 8/84)
timing chain cover 11302-38010 $282.65
timing chain guide, long - 13561-35010 $ 25.04
timing chain guide, short - 13562-35010 $ 18.35
timing chain tensioner assy - 13540-35011 $ 54.82
Rocker Arm Valve Adjusting screw - 90913-05019 $2.86
lock nut for above - 90215-42025 $1.07
water pump stud - 92122-60622 $ 1.14
water pump bolt/washer - 91651-60628 $ 1.03
water pump nut - 90179-06159 $ .43
22RE
Plate, Eng (22R-E valve cover sticker) - 11291-35040 $1.19
EGR GASKETS for 22RE -
EGR Valve and Lower Plenum Intake Assy to Engine Block (One piece) Gasket. - 17177-35050
{Note: This gasket can be cut to make two separate gaskets.}
EGR Valve to Engine Block only Gasket. - 25627-38011
Intake manifold to head gasket - 17177-35050
Plenum to intake manifold gasket - 17176-35020
EGR inlet gasket - 25628-35011
NOTE: The intake man. to head gasket comes complete with the EGR outlet gasket, there is no longer a separate gasket for the EGR outlet. The last year they were produced is 1977.
Valve cover gasket (Toyota calls it the "cylinder gasket") - 11213-35010 ($8.91)
Valve cover grommets (Toyota calls them "washer, seals") - 90210-08040 ($1.07 ea, you need 4)
1986-1995 In-Line4
Gasket, exhaust (donut, manifold to down pipe) - 90917-06038, 06045
bolt, stud (for above) - 90116-10019
nut (for above) - 90179-10070 or 90179-10175
bolt, washer for heat shield 90105-08112
Harmonic Balancer Repair Sleeve (Speedy Sleeve): FelPro 16214
Oil Pressure Sender - Gauge Type: Toyota 83520-35030
Alternator Brushes: Toyota 27370-35060
Fan Shroud: Toyota 16711-35020
Belt, Power Steering: Toyota 99332-11120-78
Belt, AC: Toyota 99332-10890-78
Oxygen Sensor: Toyota 89465-19265
Oil Dip Stick: Toyota 15301-35020
Cold start injector gasket> 23293-35020
Valve Adjusting Screws --> 90913-05019 ($2.49 ea, need 8)
TPS (throttle position sensor) 89452-14050 ~ $99
BVSV (bi-metal vacuum switching valve) 25820-13020 ~ $79
3VZE 3.0V6
Fuel Filter - 23300-65010 or 23300-65020
Air Filter - 17801-70020
Oil Filter - 90915-20001
Spark Plug - 90919-01176
Distributor Rotor - 19102-61246
Distributor Cap - 19101-65010
Rotor, Dist cap - 19102-61240
Spark Plugs (1.17) - 90919-01176
Cord Set, Plug Wires - 90919-21501
Plate, Engine Label (3.0 EFI, top plenum) - 11291-65010
Gasket Kit, Engine (all the goodies, top end) - 04111-65018
Head Gasket Kit (complete upper) - 04112-65018
FIPG, oil pan/camshaft hsg (form in place gasket) - 00295-00102
Air Flow Meter Gasket - 22275-41010
Gasket, Oxygen Sensor - 89466-20020-83
Cyl Head Bolts - 90910-02075
Cyl Head Bolt Washer - 90201-11018
Oil Pump Assy, Eng Fr Cvr - 15100-65020
Exhaust manifold, #2 (drivers) - 17110-65012
Exhaust manifold (pass) - 17141-65011
Exhaust Crossover - 17106-65010
Wire, Knock Sensor (sensor to harness) - 82219-89103
Knock Sensor - 89615-20010
Sender, Oil Pressure - 83520-35030
Sensor, Throttle control (TPS) - 89452-12040
tps - 89452-20050 $71.42
Igniter assy - 89621-30010
Thermostat - 90916-03079
Water Pump assy, cooling - 16100-69225
Hose, Air Cleaner (tb-jct box) - 17881-65011
Hose, Lower Rad to Thermostat (No. 2) - 16572-65010
Hose, Oil Cooler to Therm bypass - 15778-65010
Hose, Air intake, T-body to elbow - 17881-65011
Hose, Oil Cooler to Block (short U turn) - 15777-65010
Grommet, PCV hose (pass side valve cover) - 90480-18001
EGR Vacuum Modulator - 25870-65010
Hose to bottom of EGR Mod - 25695-65010
O2 Sensor (w/gasket) - 89465-39325
Engine Wiring Harness - 82121-89230
Oil Drain Plug Gasket - 90430-12028
Valve Cover Gasket - 11213-65010
Intake Plenum Gasket - 17176-65020
Valve Shims - 13753-65780
Valve shims - 13753-65600
Valve shims - 13753-65760
Injector O-Ring - 90301-23004
Fuel Damper - 23207-65010
Fuel Injector - 23209-65020
Timing Belt assy Parts
Timing Belt - 13568-69055
Timing Belt, Spring Tensioner - 13568-69055 - 90 to 94 (ish)
Bolt, T-belt hyd Tensioner - 13556-65010 - 1994 & up
Washer, T-belt hyd Tensioner bolt - 90201-10117 - 1994 & up
Hyd T-belt Idler Tensioner Assy - 13505-65040 - 1994 & up
T-belt Idler Assy (top w/water neck) - 13503-65010 - All
Timing cover assy - 11303-65020 - 1994 & up
Timing Belt, Hyd Tensioner - 13568-69075? - 1994 & up
Fuel System
Bracket, Fuel supply, tank top - 23206-35121
Gasket, Fuel Suction - 77169-14010
Screw, tank top supply - 90159-50157
Screw, Fuel inlet to body - 90159-60032
Hose, Fuel, short flex tank top to line - 23091-35030
Fuel Gauge Sending unit - 83320-80127
Fuel Pump, Nippon Denso - 23220-16190
Fuel Pump, Aisin - 23220-16084
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Part # Thread
« Reply #2 on: Jun 28, 2007, 09:42:09 AM »
:eek:
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: Part # Thread
« Reply #3 on: Jun 28, 2007, 09:49:04 AM »
You don't need this, all you need is this http://board.marlincrawler.com/index.php?topic=34788.0
AR80Toy [OP]
  • Turtle Points: -2
  • Male Posts: 319
Re: Part # Thread
« Reply #4 on: Jun 28, 2007, 09:53:53 AM »
I called myself searching and never could find that , thanks !!!!!!
*ROKTOY*
  • Male Posts: 1,066
Re: Part # Thread
« Reply #5 on: Jun 28, 2007, 10:09:02 AM »
Welcome
Last post Mar 19, 2010, 02:32:29 AM
by Rocksurfer
Last post Aug 26, 2004, 02:09:00 AM
by Skinny_Pedal
Last post Feb 27, 2006, 06:43:59 AM
by CTENG in KS
Last post May 23, 2006, 09:53:05 AM
by kneedownnate
Last post Apr 25, 2007, 02:19:56 PM
by CaseyP
