I'm thinking about running what I have and maybe building a motor on the side .
guys, ive seen his motor, its a 83 block
I have an 83 with a newer 85+ block. Before I know this I had ordered the timing chain for the 83 which was a single row. The info I got from Ted at enginebuilder is that 81-82 had double while 83-84 had single. Of course after figuring out that I had a newer block I had to send it back and get the the right one.
They did put single row timing in some of the early blocks, I promise.
I know, this can get confusing , Is there part #'s on blocks to tell EXACTLY what year they are ?
Thanks for backing me on that one Glen. I'm running an 82 22r block with a 78 20r head , 22r valvles aluminum rocker assembly and the dual row timing. There is no better way to make one of these motors perform on a budget.
How do you like that set up??
Started by guywithuglyyota « 1 2 3 » General 4WD Discussion
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by 79coyotefrg Rig Gallery
Started by lvhunting Toyota Pickup/4Runner Tech 1979-95
Started by GAP3RKi113R Newbie Questions
