Author Topic: Engine Layout  (Read 2132 times)
JoeShmo65
  • Male Posts: 291
  • Member since Apr '07
  • Big Red
Engine Layout
« on: Jun 17, 2007, 08:10:26 PM »
iev got a 22r engine in my yota and iev got several leeks in it and i was wondering if anyone new some sites where i could find a layout of a 22r 80-83 engine...... any ideas will help thnx  :disturbed:
"what was that daddy?"..."Don't worry honey, just a jeep i used for traction, now go back to sleep."
ROFL
Re: Engine Layout
« Reply #1 on: Jun 17, 2007, 08:20:33 PM »
you mean  for the vacuum lines ???
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
Re: Engine Layout
« Reply #2 on: Jun 17, 2007, 08:22:59 PM »
vacume lines gaslines w/e the whole shibang but ya def vacume lines
ROFL
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
Re: Engine Layout
« Reply #3 on: Jun 18, 2007, 11:47:40 AM »
no ideas??
ROFL
YotaJosh
  • Male Posts: 499
Re: Engine Layout
« Reply #4 on: Jun 18, 2007, 12:09:46 PM »
no ideas??
Haynes repair manual from Autozone? Mine has vacuum diagrams.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
Re: Engine Layout
« Reply #5 on: Jun 19, 2007, 01:07:13 PM »
I went to there website but its under constructoin and i was hopen for a free online layout o wel gues ill just go buy a manual
ROFL
cam011
  • Male Posts: 81
Re: Engine Layout
« Reply #6 on: Jun 19, 2007, 11:35:31 PM »
Try to convince someone to snap a pic of their engine for you to see where the vac lines go or hit up the pick and pull to check some out. If they're all stripped out take a look at the underside of the hoods, there's supposed to be a vacuum hose routing diagram on a sticker. With any luck you might find one that's still legible. Or you could drop the 10 bucks on a Haynes manual.
fullthrottle
  • Male Posts: 177
  • Member since Aug '06
Re: Engine Layout
« Reply #7 on: Jun 20, 2007, 04:04:03 AM »
come on! be confedent in your memory and dont  :cool: to much well your engine is apart  :gap:
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
Re: Engine Layout
« Reply #8 on: Jun 20, 2007, 11:35:41 AM »
@Cam
ya the sticker on my truck is totally gone lol but ya ill try both of those thnx
@Full
hahahahhaa i wish it was that simple but i didnt pull the hoses off the old engine some @$$ did rite as we were planning on labeling them, i was pissed!
ROFL
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • Member since Aug '04
  • J3 Productions
Re: Engine Layout
« Reply #9 on: Jun 20, 2007, 02:31:00 PM »
If you don't live in a place where you have to pass smog inspection, all you need is the vacuum line to the distributor advance and retard valve, and the brake booster if you have power brakes...it attaches to the passenger side of the intake, by the carb.
Try following this pic...
The United States Constitution © 1791. All Rights Reserved.
Only when i am finished will there be peace: The peace of an empty wind as it blows across a land strewn with the bones of my enemies.
RN37DD
  • Male Posts: 742
Re: Engine Layout
« Reply #10 on: Jun 21, 2007, 08:45:39 AM »
almost every year has a different vacuum lay out, then ya got fed, cal and Canada. to make it worst even the sticker under the hood isn't always right. my 79 had vsv hook ups and gear like a 1980 and a sticker that wouldn't work with any year. got it to work and smog by following plans from both years. if ya got vacuum leaks start replacing hose's one at a time, and if it's like mine it's got 2 sizes. also remove and check all your fittings. i had a loose fitting that seemed tight that drove me nuts.
Last post Dec 01, 2006, 11:26:13 AM
by spacoli
Last post Feb 24, 2008, 09:45:49 AM
by attitude of gratitude
Last post Dec 15, 2009, 11:36:22 PM
by Steve_925
Last post May 21, 2011, 06:29:41 PM
by BigMike
Last post Aug 04, 2011, 07:25:02 PM
by BigMike
