Air Cleaner Screw Broken
Started by Yota Tony, June 11, 2007, 01:51:12 PM
Yota Tony
So the screw that comes up out of my carb and into the air cleaner, holding the air cleaner in place with a wing nut, well it's broken off.
I'm sure someone else has run into this problem, how do I fix it?
Anthony
Looking For 82-83 Hilux - Must Be 5spd, able to run and drive, Square headlights and no rust!
82 Build - http://board.marlincrawler.com/index.php?topic=31283 - Dead
can you get the screw out? its an m6x1.0 stud.... i got a stud at my local fastener place and i modified mine to be taller....
Yota Tony
It appears to be part of the carb, at least in my eyes.
How did you get it out? Vise grips?
Anthony
mine wasnt broken off, i have a set of thru sockets and halfway down it has a nut built in to the stud.... i jsut unbolted it...
if there is any left sticking out, you can try vicegrips on it....
Yota Tony
I tried some vice grips on it just then, nothing.
I think I might try tapping it and placing a nut and stud on top.
Anthony
do you have a bolt out kit? i was able to get mine out, with some effort though. try spraying some pb blaster where it threads into the carb, and let it soak a little bit.....
Yota Tony
No bolt out kit. Mine doesn't look like it threads in to be honest.
I'll have to take a closer look tomorrow when I'm wrenching on it. I'll take some pics.
Anthony
