Being that far off, I would have to think there is a crease or crack somewhere? Possibly at the joint of one of the crossmembers. I would start looking for where that damage is. If the frame bent or creased at a contained spot, you may be able to make a strategic cut to relive the torque in the frame, then sqaure things back up.
Maybe if you remove your steering box and take a pic of the drivers side frame rail we might be able to tell you a bit more.
I'd be willing to be there was a fair amount of tension in that frame that was released when you cut out the stock crossmember. Probably didn't appear as bad till afterward?
Got a frame you can have in southern Orygun.
I've decided that I'm going to get it as close as possible by making some relief cuts. I'm not building a show car, and it's not going to be driven everyday (or even every week). It's already bent, so I don't really care if I screw it up more. Getting it to the body shop will be hard since I've already cut it up, and the bill would be more than I bought the truck for.I'm keeping my eye out for another frame (close to home) for the future.
How close I might be willing top sell ya the pristine 79 frame I have. $150 and I will deliver it next time I'm down that way, or I could deliver it for 200$
Anywhere in AR is close enough for me. Is it a shortbed frame? If so, I'll come get it for $125. How's that sound?
Do you still have this whole truck (as pictured), or is the bed/cab/etc. long gone by now?As for when, the earliest I can come is next weekend, but it will probably be July before I can for sure.
Just an update...My swiss cheese floorboards, mangled bed, bent frame, and other body/frame related crap depressed me to the point that I think I've found an '82 with a straight frame, near perfect cab/bed, no running gear, and for cheap!Stay tuned. If I get the other truck, I have to swap my engine/trans/axles to it. Oh, and I'll have to swap my headlight buckets, grill, and other trim 'cause I'm keeping the round eyes.
Started by luckyvonpanzer General 4WD Discussion
Started by notoyguy Toyota Pickup/4Runner Tech 1979-95
Started by Yogatoy General 4WD Discussion
Started by Tice General 4WD Discussion
Started by Sparkplug Rigs For Sale
