Crawler length confusion.....
Started by emsvitil, June 04, 2007, 08:57:29 PM
emsvitil
I searched the forum, and found (in various spots) that adding a crawler adds 6.5" to your transmission/transfer case....
I also found in a tech article that the adaptor plate is 2.375" long.
I just measured the front section of my transfer case (gear drive, top shift) as 3.21".
Isn't the crawler the front section of the transfer plus the adaptor plate?
If it is, that adds up to 5.585"
Where did the missing .915" go?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
MiniSimp
#1
Maybe I can help confuse you more...
From the back of my MC08-R10 to the front of the crawl box is 6.5" :greengrin:
emsvitil
Well I misread the caliper (I took a quick look before)........
Luckily, I had locked the caliper and noticed that it's 4.21" when I was putting it away.
So thats 4.21" + 2.375" = 6.585"
So now I'm .085" long............
Is the adaptor actually shorter than 2.375" ?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
fullthrottle
not to sound like I'm bashen you but y do you want to know so accurately how long it is.
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
Loosekannon
Quote from: fullthrottle on June 05, 2007, 04:41:07 AM
x2 :headscratch:
Rockcrawlintoy
he prolly wants his d line made before he does duals.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
emsvitil
Quote from: Rockcrawlintoy on June 05, 2007, 07:06:21 AM
Drew
And I want to make a triple shifter on top of the crawler box, so I need the precise distance between the 2 top shift locations so it will just bolt up.    (I just rebuilt my transmission, and measured the specs for the transfer shifter, the only unknown is the distance between them)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
MiniSimp
I'll measure the distance between shifters for ya when I get home today. :yesnod:
emsvitil
Quote from: MiniSimp on June 05, 2007, 11:04:31 AM
Thanks........
(rotated case or not.....non-rotated triple shift is easier.... hmmmmm...)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
MiniSimp
Ok, it is exactly 5.0" from the center of my rear transfer case shifter to the rear screw on the transmission/transfercase cover that has the boots on it.
emsvitil
Quote from: MiniSimp on June 05, 2007, 01:47:55 PM
Is the cover attached to the transmission or the hump?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
MiniSimp
Quote from: emsvitil on June 05, 2007, 04:29:54 PM
To the tunnel. 6 mounting holes, 2 boots.
