Just attempted to install a New Style ARB w/ 5.29s
I had clearance issues with the way the copper tube was routed over the ring-gear. Every-time I slid the 3rd member in, I had no issue until I was tightening it down. That was when the copper line was making contact with the back of the housing (IFS Rear Housing). I tried tweaking the line to fit better, but no luck.
Then I went to look at an old ARB 3rd I had laying around and that's when I discovered that in the old style ARB, the copper line does not go over the ring gear.
I have no clue as to why they designed the new one to be such a pita...
So heres what I did just in-case anyone else has the same issue.
I re-routed the copper line as shown.
Has anyone else run into this problem? ...or any other suggestions?
