Marlin help ! P/S vacuum lines??
Started by VueDoo, April 05, 2004, 01:18:13 PM
VueDoo
I have a newer? style P/S pump with a fitting with two vacuum lines(variable assist I think). I don't need the lines. Do I pull the "vacuum pod" off the pump and plug it? or just leave the line disconnected? or what ??? I want to be sure to get as much flow and pressure as possible, it's running my full hydro steering :thumbs:
Thanks, Phil
I spent most my money on booze, broads, and 4x4's; the rest I wasted!
Marlin
Most people leave the lines wide open, since the valve is only used on a efi truck when the wheels are pegged [very high p/s pressure]. It works by letting vacume from the intake mainafold flow thur the valve and connect to the front side of the throttle body which causes a vacume leak and the motor them speeds up. This prevens a shot of unburned fuel that could damage the catalitic converter.
Nothing will happen if you leave the lines wide open :thumbs:
I beleive that Toyota sells a plug-i will check monday
Marlin
VueDoo
Thanks Marlin :bowdown:you da man.  BTW the decals look good on the buggy  :thumbs: just hangin' in there for the front drive t-case ;)
Phil
