complete 3rd installation
Started by Hayes, May 20, 2007, 08:53:47 PM
Hayes
Anyone know where I can find the isntall instructions for the complete 3rds.  Just ordered my lock-rite 5.29's from Marlin.  Said they are about 7-10 days out on building the units and then I have to wait for the man in Brown...
Just thougth I should start prepping for the install, getting tools and extra things I might need.
Thanks,
Brandon
`85 4runner / auto / 3'' lift / 33 x 1250 x 15 BFG Mud Terrains on 15 x 8 MB Motoring Blitz (-19MM offset) / 1.5'' Marlin wheel spacers (f-r) / CB and antenna / soon to be geared and locked f-r /
you'll need a 10mm for the brake lines  a 14mm  for the brake drum backing plate to housing bolts,4 on each side
then you'll  need a 12mm   to remove the  nuts  around the 3rd
oh  and  remove  the drive shaft  :smack:  forgot that
AaronB
Rockcrawlintoy
and dont forget to refill the oil my buddy did that once.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
RTA
How about two rubber caps to stop the brake fluid from driping. :psss:
So. Cal. ROCK BRAWLERS
DTB
some RTV and a new gasket. Check your axle seals if they are in bad shape replace them
