It doesn't sound like you are ready for this judging by the questions you are asking.
The only thing a V8 is good for is breaking . You don't need a big motor is you have the gearing.
V8s rule for wet ground, mud, and steep hills. Gearing won't help you on steep muddy hills or obastacles that require momentum. If you have gearing and horsepower you will be in good shape, but gearing is far more important for 90% of the things you will come across. In the midwest a combination of horsepower and gearing is necessary due to the ever changing conditions of the trails from the weather. A trail could be dry and crawlable one day, then wet and sloppy and only passable with the go pedal the next day.
Other engines like a 4.3 chevy are great swaps because you can get some extra paower without adding all the drivetrain weight of a v8 swap, tires.
i love your sig your down to a half of a maverick
not trying to sway your way from a v8 swap...just saying if your thinking about a chevy driveline, you'd might as well go with a 302 swap, or some other v6/v8 as you;d get comparable power with less weight..a lexus 4.0 sounds cool, dont think they weigh over 450 either...and its more of a hp motor then a torque motor..they might acutally have a kit for it now..just something to think about..http://www.uzswap.com/forum/index.php?topic=7.0
How much does a Vortec 5300 weigh? That would be a really cool swap if they aren't too heavy.
Started by yodersgirl Toyota Pickup/4Runner Tech 1979-95
Started by Toyota_Dave Toyota Pickup/4Runner Tech 1979-95
Started by Hottrod81 Project Research and Build-Ups
Started by Dr.Maxwe001 Toyota Pickup/4Runner Tech 1979-95
Started by zebracrawler Engine
