what width rim with your 37 mtr?
Started by donutman126, May 12, 2007, 03:51:19 PM
teh rule of thumb is 4" tire to rim... but when i worked at a tire shop, if we could get the bead to seat it was all good.... i remember mounting 33x12.50s on the stock sr5 15x6 rims on a customers first gen truck....
Gewehr43
Think the stock 15X7 wheels would be fine with a 35X12.50R15?
Reynolds
15x7 should be fine. I run 15x8's on my 37" MT/R's. The 15x10's were nice for tire wear (much more even tire wear) but not so good for rock rash on the wheels. I like the 8's because the tire gets a little taller and narrower and the bead is tougher to peel off the rim when aired down. Downside to 8's is tire wear isn't as even.
-Brian
Shamb
I've used 15x8's and 15x10's  on the 37" MTRS when I had them. Didn't really notice a different from the two..
Ran both at 5psi and never blew a bead, I guess I liked the looks for the 8" rim a little better  :dunno:
Geno
I run 15x10 with my 37" MTRs.  In the snow I run 3-4 PSI and on the rocks I runs 4-5 PSI depending on load.  I have never blown a bead.
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
skid
Quote from: Geno on June 03, 2007, 05:06:45 PM
kinda funny, in the snow we ran mtr's  at 1-2 pounds with no bead locks, never a problem.  Friend  lost a bfg inner bead with outter beadlocks first time out at 5 psi.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
46&2
Quote from: skid on June 03, 2007, 09:02:48 PM
Yeah, MTRs are a bad ass tire. I usualy run BFG muds but i have neve run those under 8 psi. I will most likely get a set of mtrs when it comes time to buy new tires because everyone i know that has them swears by em. Hell I practically swear by em and I have never even owned a set. Riding and wheeling with my MTR buddies was enough proof for me.
Brandon
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
