Author Topic: 22RE questions  (Read 1552 times)
SACD_Runner
  • Turtle Points: 2
  • Male Posts: 217
  • Member since Mar '07
22RE questions
« on: May 11, 2007, 09:13:59 AM »
Hey all, I have some quick questions about our 22re's, it seems like mine is going crazy. First, where is the powerband in our rigs. Im getting a flat spot in the 2200-2900 rpm area. It falls flat on its face then when i get to 3k it goes, almost feels like turbo lag. Sounds like it wants to go but can't.
Also my temp guage says that my temp is fine but when i touch the radiator/head... it's very hot. like burn your freaking hand hot. just want to make sure this is normal, if i remember right my 22r never got that hot. maybe a thermostat?
And lastly, last week i went out and got new calipers/pads/rotors put on and the pads seem to be still rubbing on the rotors when i jack up the front and spin the tires. Could this be a Master cylinder prob, or should there be rubage? I had all of this replaced because i thought my rotors where tightening causing my flat spot in acceleration.
If you want any pics, just let me know. Im gonna check to see if i have any bubbles in the system then go from there. Thanks-Justin
Starting from scratch again...
SACD_Runner [OP]
  • Turtle Points: 2
  • Male Posts: 217
Re: 22RE questions
« Reply #1 on: May 11, 2007, 09:52:57 AM »
here's some more info. this morning i bled the radiator, it gargeled at the begging but then stopped. So im hopping i got some bubbles out. i also noticed that my rig only idles at 500rpm's when its warming up, shouldn;t it be at 1500? Pics are a comin.:)
SACD_Runner [OP]
  • Turtle Points: 2
  • Male Posts: 217
Re: 22RE questions
« Reply #2 on: May 11, 2007, 10:39:07 AM »
here's some pics.
These two are what it fluxuates back and forth from when warm.
this normal oil press?
exposed wires on the temp sensor. crapy pic.
91 super yoda
  • Turtle Points: -56
  • Male Posts: 400
  • Member since Sep '04
  • Axe' em Jacks
    • Old Town Customs
Re: 22RE questions
« Reply #3 on: May 11, 2007, 03:02:21 PM »
The radiator is always going to be hot, you may have a stuborn thermostat but if it doesnt overheat i wouldnt worry about it.
Do you have vented rotors or non-vented, the thickness in the pad makes a difference between those 2. but if its just a light scrape that would seem to be pretty normal to me.
you can re-adjust your idle with the screw on top of the throttle body.
my power band (if there is one on a 22re) is 3000 and up, i dont have a lot of power from 2200-2900, but if its really slugish it may be an ignition timing problem.
fullthrottle
  • Male Posts: 177
  • Member since Aug '06
Re: 22RE questions
« Reply #4 on: May 11, 2007, 05:04:26 PM »
you have a 4runner right, 4runners are kinda hevy for that motor and stock power band for the 22re is 3000 to almot 5000 if you turn your idle up a little it mite help don't go much higher than 1100 for your idle
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
SACD_Runner [OP]
  • Turtle Points: 2
  • Male Posts: 217
Re: 22RE questions
« Reply #5 on: May 11, 2007, 06:49:47 PM »
cool, that makes me feel alot better. I'll check the timing, for some reason i think its off. Good news is that i checked the plugs and they all looked really good. Thanks guys for the info.
Last post Jul 22, 2007, 07:07:52 PM
by gtoyonrocks
Last post Oct 21, 2007, 08:21:34 PM
by LOL @ IFS
Last post Oct 28, 2008, 12:36:18 AM
by CrawlerBrennan
Last post Mar 11, 2009, 05:26:20 PM
by yjay
Last post Aug 30, 2010, 01:12:54 AM
by KDXSR5
