High Pinion Clearance ????????? need help
Started by AaronB, April 17, 2007, 07:20:05 PM
AaronB
I got a high pinion third that im trying to get in my housing. I had a really hard time getting that sucker in there, my problem is now that its in there i need to get it back out because my arb copper line came out. Was I supposed to clearance the housing first?
Thanks, Aaron
pull it  out  till the  ring gear  hits  then  rotate the pinion,  should  be able  to pop it on out
a  little  wouldnt hurt,  but  if  it goes in dont worry bout it
AaronB
so should I have clearanced the housing first?
yea  it would have helped
btw  im moving this to tech
AaronB
AaronB
I finally got it out!!! Then I clearanced the housing and it slid back in like butter. Thank God, I was getting way to pissed off.
