Clutch replacement
Started by 85 and still running, April 06, 2007, 07:35:51 PM
Sorry, newbie question...
I am replacing my clutch this weekend. According to Chilto I need a special service tool in order to remove the transmission shift lever. Any recommendations on where I can purchase this tool? ???
insane04
BS just unblot the bolts holding the assembly to the trans housing
Thanks. Just what I wanted to hear. :biggthumpup:
yup, its eitehr got bolts or it does liek a half turn press down thing
cheap sunglasses
I use a pair of pliers. Push and turn counter-clockwise 15 degrees or so. Not much to it.
'82 on 35's, not much else.
Thanks for the info. Got it done today. Was able to do it myself by putting a cinder block of the floor board of both the drivers and passengers side and run two 2x4's across like a header to a door. Then, I used a ratchet strap to raise and lower the unit.
Thanks for the assistance. Now I need to get out and try my new 4.7 Marlin case!
I needed a new clutch but I also had a noise coming from the tranny once speeds reached above 40 MPH, usually occurring once I hit 4th gear. The noise appears after I push the clutch in to shift or coast. It also shows up when I am cruising at freeway speeds and let off the gas. It sounds like the throw out bearing but, I replaced it and the pilot bearing. NOISE STILL THERE!!!!
Has anyone else encountered this problem and found a successful fix?
sounds like a rear  diff  problem
No. It's definately coming from the tranny. I have the cover off around the shifters so I can hear better as I travel down the road.
SACD_Runner
I have the same (EXACT) problem and have yet to find the cause. i've changed u-joints and checked everything. The noise wont go away, i was hoping it was the throw-out/pilot bearing but i guess not. :( lemme know if you figure it out, i'll do the same if i do.
Starting from scratch again...
highridin4x4
When you had the tranny out did you see any input shaft play? My input bearing has gone out on me twice so this time I rebuilt the tranny with marlins heavy duty bearing kit. My noise was there all the time it just got louder the faster I went. Here are a pic of the bearing.
Scott
SACD_Runner
how hard is the replacement of the input bearing? Is it something 2 guys can do in a driveway without a press? Im planning on buying a new clutch throw-out/pilot bearing along with marlins bearing kit. Just want to make sure its something i can do. Thanks
highridin4x4
The input bearing is one of the bearing that are easier to get off but you will have to take the tranny apart to get to it. The other bearings are kind of a pain to get to you will need a press or a long puller. On a scale of 1 to 10 I would give it a 8 on the technical scale. I did not do mine at home I did it at work on the weekend. Good luck if you decide to do it yourself.
Scott
Goose
highridin4x4, what kind of noise are you hearing?
I'm getting this wonderful grinding and screaming sound, but it sounds more like its coming from the rearend...  :think:
I figured pinion bearings are about fried since my trucks got over 350k and both the bearings in the front just puked all over themselves... (robbed the bearings off a buddies extra ifs parts :D$free$)
I'm not sure if any of you are familiar with bigger trucks (peterbilts) but it sounds like a truck when its in high overdrive...
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
highridin4x4
The noise I was hearing sounded like worn out gears in the transmission 1st 2nd 3rd and 5th at first. Then I lost 4th gear altogether because 4th gear is on the inputshaft and the whole staft was moving out about a 1/4 inch.
Scott
