new parts i got.
Started by Hyena, March 13, 2004, 06:38:54 PM
I just got 63" chevys today, hopefully will be on by next week.  I will also be picking up a duel transfer case next weekend.  For $725 i will be gettting the duel cases with the inchworm, two drivelines (one is a brand new high angle driveline for the front), and a Sky crossmember/skidplate.  The drivelines i won't be able to use because they are to an 83 and the bolt pattern is different.  Hopefully the cases will be in in the next month or so.  Its gonna be sweet once it and the chevies are in.
cruzila
KYOTA
brainlessfool
Marlin
#4
Wish you would of given us a call.
My coupler is a new billit design that is .300" thicker than the factory output shaft.
And my center bearing is wider and much stronger than stock.
We do not shorten, bore, and then respline the factory output shaft.  :moon:
I have never made a coupler that is weaker than stock :_oops:
Marlin
I wasn't really planning on buying it, only the chevies.  But it was a good deal i guess i needed one sooner or later so y not right now.
cruzila
Alright, put away the rope boys.
brainlessfool
awwwwwwwww :rivers: I love a good linching :_oops:
Prismo
