smog
Started by ihanberg, March 10, 2004, 10:50:17 PM
ihanberg
how do i smog my 85 4runner wich origionally came with an automatic but now has a 5 speed
Marlin
#1
In the republic of California, you need to take your truck to a smog shop and have it smogged. Because the VIN stays auto, your truck will fail. Next call the bureau of auto repair, the # is in the phone book under "State of California". You will need to call and get an appointment with the referee to get it smogged.
Since both auto and stick use the same emissions, you should have no problem.
Did you change the engine computer? It is difference for a stick shift.MC
ihanberg
i am picking up my tranny today from tap in rancho cordova the guy told me he would sell me everything to do the swap for 969 dollars im not sure if that includes the cumputer.thanks for the prompt reply!
NNNNOOOOOO not tap!!!!!! Youll regret it till the day ya die I swear!  Theyll cause you nothing but headaches.  Id be willing to bet you could get the whole setup from people on this board for about half of what tap wants!  They are nothing but crooks trust me!
WT
84runner
PREECH IT WHITEY AMEN BROTHER
