Differences in 22re's?
Started by Cheesemaker, March 16, 2007, 03:13:44 PM
Cheesemaker
I've got a line on a 22re that supposedly needs a head gasket.  The guy bought the truck for $800 for parts.  I was told it might be a 92, I have a 87.  Now there was something about a cutoff year were things changed with the 22re?  If I remember it was 85 to 91 had the same wiring efi setup?  And the TPS was changed to a 3 wire in 92!  Am I right?  I there any other diference I need to know!  Please help me out on this!  I might get this motor cheap!  If I can get any help on this, it would be awesome!!  Thanks!
toyo487
As long as you get the ecu and engine wiring (which you will need anyway because you have a turbo EFI) Then you will be ok.
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7's in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
dcg9381
Get everything.  There were injector impedance changes, ECU changes, and wiring connector changes 85-91, the big year is mid-1988...
[email protected]
www.22returbo.net
www.2rzturbo.net
Cheesemaker
Will the efi intake manifolds bolt up to all 22re's?  Even if I got a newer motor?
Gittinit
Quote from: cheesemaker on March 18, 2007, 01:48:26 PM
Intake bolt batterns should be the same for all efi heads.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
