85 toy changing from auto to stick
Started by usmcab35, March 15, 2007, 04:00:04 PM
usmcab35
im planning on changing my 85 toy pickup from auto to 5spd. has anyone done it or have any suggestions?
*** YELLER ***
SEMPER FI  :biggthumpup: hows that fer a sugestion  :dunno:
:usa: :beerwhack:
except BACON
ToYocRawleR
Im planing on doing it also.  Its easiest if you have a donor 5spd cab so you can just transer everything over.  You will have to drill a hole for the clutch master cylinder plus you will obviously need all the lines, pedal assembly, slave cylinder and maybe a 5spd. ecu. Plus the big stuff ie: tranny/tcase.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
usmcab35
couldnt you just get all the stuff minus the cab????
usmcab35
has anyone else done this or know the best way to do it????????
brainlessfool
I know you should change the ECM when you do it. will run better.
Auto and 5spd ECM's are diff.
myyota
My cousin just did this to his 86 4 Runner, you don`t need to change the computer, it will not affect the engine operation, my cousins truck runs just fine with the manual transmission in place of the outomatic. you just need to start gathering the needed parts and then plan on spending a weekend or longer getting everything put together.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
854RUN
I did it to my 85 runner, go to the link : http://board.marlincrawler.com/index.php?topic=23833.msg254308#msg254308
and it will tell you every thing. Its pretty simple
-JOSH-
