1984 4runner SR5, Crawler/DD, Chevy 4.3L V6, nicely Built, Duals, locker, Long
Started by jeffs84runner, March 03, 2007, 09:56:20 PM
jeffs84runner
SOLD!
1984 4runner SR5, Crawler/Daily driver, Chevy 4.3L V6 swap, nicely Built, Dual stock cases, EZ locker Rear, 30 spline Longs in front
Well, I'm putting my baby up for sale.  Got married a couple years back and just had our first baby, so I've decided to move over to an FJ80, better for the family, so I will consider trades for 95-97 FJ80's.  Truck is in Fresno, CA
<a href="http://s63.photobucket.com/user/84runner/media/IMG_0106.jpg.html" target="_blank"><img src="http://i63.photobucket.com/albums/h149/84runner/IMG_0106.jpg" border="0" alt=" photo IMG_0106.jpg"/></a>
History –
I bought this truck in stock condition in early 1999 from the second owner in Willow Glen, (San Jose), CA with 73,000 original miles.  The truck has 117,000 miles now.
The original owner was from Costa Mesa.  I have all previous owners paperwork going back to the original sale including; window sticker, original owner's manual, owners driving guide, brochure etc, and all services performed.  You can see why it had low miles; he only drove about 7K miles a year.  My idea was always to build a crawler from a low mile, nice condition truck, so I would know that I was starting off in great condition.  I drove it as my daily driver for 2 years until 2001 when I bought a commuter, that's why it still has relatively low miles.  I've only gone on truly only 1 or 2 wheelin trips a year, so it still hasn't seen a lot of use.  I did the engine swap to a Chevy V6 in 2004.
Drivetrain/Axles -
Engine - 1989 4.3L TBI V6, smogged and CA legal.
(also have spare Cadillac air filter intake; would be an easy beginning for snorkel set-up).
Tranny - 700R4 tranny.  Lokar 12" shifter http://www.lokar.com/interior_pages/products/shifters_knobs/images/standardshifter.jpg , Be-Cool Radiator w/ fan, (mounted on front fender, fan not wired)
   A/A T/C adapter
   Downey Off-Road Speed sensor
T-Case – Dual stock cases – Marlin #617
Lengthened stock front driveshaft in front
1996 front driveshaft lengthened for rear, (Marlins suggestion of a 96)
Shortened stock rear shaft for trail spare
Front axle:    4.10 R&P open diff.
30 spline Longfield, (never broken a birf though)
   3" wheel spacers – Marlins
   2" drop down hanger
Rear axle:    IFS rear axle Swap
   4.10 R&P - Detroit EZ locker
Diff Breathers Front and rear
Engine Swap -
The Chevy S10 4.3L TBI Engine swap was done back in late 2004, and I bought the engine/tranny as a complete package directly out of another Toyota truck that had been smogged in CA.  Included in the package was Complete engine w/700R4 tranny, A/A transfercase adapter, Downey's vehicle speed sensor, advanced adapters 4 core radiator.  I bought the Lokar nostalgic 12" shifter so it would work in the stock location as the shift boot, looks very clean.  Drivetrain lifted about 1 ¾" at engine and crossmember.  I used a Fuel Injected 4runner gas tank with an AC Delco (OME from Chevy) fuel pump inside the fuel tank.  I also made a new 3/8" fuel line from tank to intake, to accommodate higher fuel rate of the TBI.  As far as electrical goes; the previous 4.3 owner showed me how easy it was to wire up so I didn't go the route of a howell or painless wiring harness.  Basically the 4.3 factory harness attaches to the ECM which I located under the dash on the passenger side.  There are a few wires which are either hooked up to power or ground from the ECM.  There is also a wire for the "Check Engine Light," which I used an LED on top of the dash, (should be visible in guage pic).  Temp gauge wired no prob.  Had to use an aftermarket gauge for oil pressure.  Fuel gauge line fit the Toy tank plug perfect.  Tach gauge is hooked up.  Mechanical fan works perfect never gets warm.  Previous owner didn't have a shroud and said it didn't need one, but I made an decent aluminum shroud and it's never overheated.
Interior -
SR5 =  tiltometer, altimeter, PS, PB, tilt, (CC removed during engine swap), gauge package; speed, tach, temp, volt, fuel, oil, (aftermarket oil guage).
Wet Okole Seat covers
Inner cage Smittybilt
Alpine CD with Polk Audio 6x9's
Uniden 40ch CB with Firestick antenna
Suspension/Lift/Tires -
Front:    Modified stock Toyota rear springs up front – 6 leaf pack, soft, very little lift. Relocates front axle 2.5" forward
   2" drop down from frame
   All Poo Greasable shackles
   Ubolt flip kit
Marlin shock towers
Shocks Front: Poly Performance's BBCS – 15"
Rear:    Chevy ½ tons, shackle moved back
   Ubolt flip kit
   Shocks Rear; Rancho 9012's  - Wide " / \ " mounted pattern for soft ride
Body Lift;
2" UHMW Polyurethane body lift – 4crawler (Roger Brown)
Tires/Wheels;
35" Pro-comp Xterrain's on 15x10 black steel wheels, less than 3000 miles on them. (35" BFG Mud T/A spare)
Brakes -
New Rotors in Front back in 2000.
Bigger IFS drums in rear
Wilwood brake prop valve, in rear
FJ80 Brake master cylinder
Steering -
High Steer Crossover steering kit – Marlins (gold anodized = bling!)
IFS steering box
Body Protection / Armor -
Front Bumper w/ stinger Black Powder Coated – custom built by HannaQuality.com
Rear Bumper w/ swing away tire carrier & receiver Black Powder Coated – custom built by HannaQuality.com
Rock Sliders – Marlin, (set up the same as his truck)
Dual Crossmember – Budbuilt (Pt # BBUD)
Innercage
Extra parts -
Extra "half top" over rear passengers
2 extra rear side curved windows
Rear Driveshaft
Tons of extra hardware.
*Newly added*  The truck is due for a smog, which I will have done in the next week, and should pass with flying colors.  The truck does have a bit of rock rash basically on the lower right rear quarter panel, I've basically touched them up but never done any body work, (pics to come on Wednesday).  The top of the cab and hood have been repainted because of the clear coat pealing off, (pics coming Wednesday).  The windshield has a circular crack down in the bottom corner of the drivers side windshield.  Driver and passenger window were lightly tinted by previous owner.  Toyota had A/C but it hadn't worked since I bought it.  There is an estimate the previous owner had done for work needed.  The Chevy Engine has an A/C compressor and I have the factory hoses that just need to be retrofitted to each other, I've just never got around to it.  Asking $8400 Or best offer.  Truck is in Fresno, CA      Email me @ [email protected]
1984 4runner sold :-(
1997 FZJ80 sold :-(
1995 SAS'd 4runner sold :-(
Current Whip 1996 LX450
Rubicon Tested, Mother Approved...
Buy Marlin!
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
Tumbleweed
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
BTT.
Here's a pic of what the "half top" looks like...  :)
And what 35 PSI in the tires looks like!!!  :nonono:
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
Things that I thought needed to be added, (added to orig add above);
*Newly added*  The truck is due for a smog, which should be done in the next week, and should pass with flying colors.
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
*added to original post*
Engine Swap -
The Chevy S10 4.3L TBI Engine swap was done back in late 2004, and I bought the engine/tranny as a complete package directly out of another Toyota truck that had been smogged in CA.  Included in the package was Complete engine w/700R4 tranny, A/A transfercase adapter, Downey's vehicle speed sensor, advanced adapters 4 core radiator.  I bought the Lokar nostalgic 12" shifter so it would work in the stock location as the shift boot, looks very clean.  Drivetrain lifted about 1 ¾" at engine and crossmember.  I used a Fuel Injected 4runner gas tank with an AC Delco (OME from Chevy) fuel pump inside the fuel tank.  I also made a new 3/8" fuel line from tank to intake, to accommodate higher fuel rate of the TBI.  As far as electrical goes; the previous 4.3 owner showed me how easy it was to wire up so I didn't go the route of a howell or painless wiring harness.  Basically the 4.3 factory harness attaches to the ECM which I located under the dash on the passenger side.  There are a few wires which are either hooked up to power or ground from the ECM.  There is also a wire for the "Check Engine Light," which I used an LED on top of the dash, (should be visible in guage pic).  Temp gauge wired no prob.  Had to use an aftermarket gauge for oil pressure.  Tach gauge is hooked up.  Fuel gauge line fit the Toy tank plug perfect.  Mechanical fan works perfect never gets warm.  Previous owner didn't have a shroud and said it didn't need one, but I made an decent aluminum shroud and it's never overheated.
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
Oh yeah, I sorta copied somebody elses mounting angle and width for their sliderz... ummm... some of you may know this red truck!   :ha_ha:
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
*added to orig ad above*
Oh, front and rear bumpers are Powder Coated black for that looooong lasting shine!!!
1997 FZJ80 sold :-(
Buy Marlin!
AaronB
Man I really love your runner! want to trade for my 83 project and some cash!!!!
:gap: :greengrin: :wink2:
Ill keep dreaming!
jeffs84runner
Quote from: Aaronb on March 06, 2007, 11:46:41 PM
Ill keep dreaming!
If by "83 project" you mean a low mile sweet 95-97 FJ80... then yeah, that's what I'll be getting...   :beerchug:
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
Both 84 Toyota and 89 chevy S10 Factory Service Manuals. Just shy of a hundred bucks each!
Extended Front stock Driveshaft in Front
Spare stock rear driveshaft cut, rebalanced, trail spare
1997 FZJ80 sold :-(
Buy Marlin!
4stair
hey man i posted up on yotatech and you said to post over here due to some yota tech problems...
88_Pathy
Where in Fresno is it located?  I would like to come look at it.
jeffs84runner
Quote from: 4stair on March 07, 2007, 08:40:55 PM
Yep!  I couldn't reply over there.  You see all the extra pics over here huh!!!
1997 FZJ80 sold :-(
Buy Marlin!
4stair
yeah is it a true daily driver?  i am curious cause if i do decide to go this route i would have drive it back to pa...
Prismo
jeffs84runner
The main thing it is missing now is a sway bar with these soft springs and shocks.  Either here or on Pirate there are links for sway bars options for 84-89 p/u's and 4runner's and such using tacoma sway bars.   I have the stock 84 sway bar that now does not fit due to the forward position of the front axle, but there are posts on Pirate4x4 of guys using tacoma sway bars on early toys...
1997 FZJ80 sold :-(
Buy Marlin!
4stair
not terribly worried about a swaybar, my dd 1st gen pickup is lacking one of those...
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
Quote from: 88_Pathy on March 07, 2007, 09:10:42 PM
You gotta be :pokinit:'n me, right?  Um let's see... You've heard of Marlin Crawler right?  If not take a look at the website you're on, or go here;
www.mapquest.com
and type in "Fresno" and "CA"
:beer: :beer:
1997 FZJ80 sold :-(
Buy Marlin!
AaronB
Quote from: jeffs84runner on March 08, 2007, 05:59:21 PM
www.mapquest.com
:beer: :beer:
:headscratch: He said where "IN" Fresno. not where "IS" Fresno :laugh:
jeffs84runner
Hahaha, Don't I look like the F'n A'hole!!! my bad...   How about north Fresno, about 1/2 mile east of 41 on Friant by the new OSH.
1997 FZJ80 sold :-(
Buy Marlin!
jeffs84runner
Just got my FJ80!  Need to clear room in the Garage...
1997 FZJ80 sold :-(
Buy Marlin!
AaronB
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
88_Pathy
Is it out at OSH or is your house around there.  I live very close so I would like to check it out.
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
dizzydevil
Perty fj But id rather have the runner! To bad the only way i could get it is to divorce my wife! I have dumped to much into my 80' pickup she'd kill me if i told her i was buying something else...bump for a sweet runner
jeffs84runner
1997 FZJ80 sold :-(
Buy Marlin!
