New Product - MC07-R10 Rotated Cast Adapter
Started by BigMike, February 09, 2007, 01:50:06 PM
89 toy
can i send in my twinsticks and get the ones for the clocked adapter also
89 ext cab sas with diamond +4 1/2" housing 30 spline longs and hub gears, hp elocker, six studs, arp studs in everything, taco rear with elocker. swaped out 22re for 3.4l supercharged, urd 2.0" pulley, urd fuel management, downey headers, flowmaster, cold air intake, marlin clutch that is straining to hold up
MiniSimp
Quote from: 89 toy on February 16, 2007, 01:13:47 PM
Or you could save some time and just bend them 10* to the right.
#32
We offer Twin Stick Shifters at 0° and 10° rotation.
A 20° version is not being offered at this time.
I suppose we would charge a small fee (like $5 ???) to bend the shifter. It seems really silly to have to charge for something like this though
Do you have access to a vice? They are extremely easy to bend to your desired position.
skid
x2 on the shifter bending.  Easier than packing it up to ship.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
MT4Runner
Let's see if this attachment works...just did this in MS-Paint...when I saved it as a .gif, Paint turned the gray into blue.  I hope it isn't too "offensive" looking.
Shawn
TheBandit
Quote from: MT4Runner on February 16, 2007, 02:06:59 PM
Shawn
Shawn, you are a genius!
Marlin Crawler, please make a sticker per MT4Runner's design!
skid
I've got more balls beneath my two sticks(4 if you count all of them)?  Ohh, the ideas.
Talon84x4
Central Valley Crawlers
dirtyskivies
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
MT4Runner
dirtyskivies:
Quote from: BigMike on February 09, 2007, 08:01:43 PM
Yes, if it is new and has not been installed, then we would be happy to swap. :gap:
MiniSimp
91Toyota4x4
Do you guys have a date on the 23 spline version?  I was all set and ready to order on Friday but when I called they said that they didn't have the 23 spliner's available :(  Isn't it just the coupler that is the only difference?
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
kiyul4130
yep. ready to order up my stuff pretty quickly here and wanted to get the 23 spline through out cause i got the v6. anything available before hammers??????????? please!
thanks
-kiyul-
ECV 7-11
KYOTA FOREVER
robrub00
Quote from: 91Toyota4x4 on February 18, 2007, 06:56:45 PM
yikes!!!!! i called and sent mine in i thought it was just the coupler too.  i need mine to be 23 for my turbo tranny?  can anyone confirm this??
bunch of stuff for sale!!!!------> http://board.marlincrawler.com/index.php?topic=31225.0
MT4Runner
robrub00
 i called them yoday.  they are back ordered on couplers is what they told me
kiyul4130
ok so it will work, you just need the correct coupler. perfect.
-kiyul-
ECV 7-11
KYOTA FOREVER
TheBandit
#48
Quote from: shadycrawler on February 13, 2007, 11:16:08 AM
Please send it back with a copy of the receipt or your order number and we'll be happy to trade it out for the rotated adapter.  You just need to send back teh plate.
-Steve
Steve, I sent out my non clocked adaptor plate today via USPS to exchange for the new clocked version. Can't wait to see the MC07-R10!
I can't tell you how happy I am to see the cast R10 come to fruition. If you can come up with a good bolt-in crossmember for this, you'll be in business.
Imuz Me
So here is my question, I just spent 20minutes or so reading BigMikes write up on why the MC-07 is so much better and superior to the MC-05.  The feeling I got is that the 05 is now :pokinit: and "YOU" need to buy the 07, come awn, what gives?  I have MC-05 #402 a lucky 12 numbers before they changed to the 07,  so it appears that since I'm playing on borrowed time before it fails, am I up :pokinit: creek?  Do i have a leg to stand on with warranty and what not?  Curious?
My #402 has been in a buggy since 2003 and does not see much high speed anymore.... if that matters....
thoughts......
IMUZ.
MT4Runner
You've been thrashing on a 10 year-old adapter for 4 years now in a buggy?  I'd guess if it was going to break, it would have already broken!!!  :D
Rockcrawlintoy
Quote from: MT4Runner on March 06, 2007, 02:33:55 PM
it was in a full bodied 4 runner i think before that
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
TheBandit
Thanks guys! The clocked adaptor showed up today. I am MC07-R10 #030. :D
MT4Runner
Fit and finish on these things is gorgeous--nice oil passages, very efficient casting--the casting on the exterior follows the passages around the bearings inside beautifully.  I would have to guess that these things are 3 lbs. lighter than the standard MC07.
MT4Runner
Billet doesn't really get me off--but this beautiful casting does!!!  :bananasplit:
TheBandit
Shawn you suck for getting no1!
Great pictures and you are right; this is a nice piece!
skid
Quote from: MT4Runner on March 09, 2007, 08:39:06 AM
Yeah, we all know you like it rough!
rivercat
is a body lift or floorboard mod required to run this clocked adapter? i would be installing onto a '95 4runner 22re
95 4runner 22re
kiyul4130
Quote from: rivercat on March 13, 2007, 04:05:54 PM
no floorboard cutting should need to be done. you can actually tuck it up there higher with a body lift. the clocked adapter lifts the bottom of the case up. its just twisting it not lifting the top or anything.
-kiyul-
ECV 7-11
KYOTA FOREVER
Bazzi
uuuu I don´t think you can rotate or twist the t-case without lifting the top... ok basicly you lift the right side of the t-case so the drive shaft lifts and you there fore have a flat belly.  ?? right ??  but the actual top of the t-case turns slitely to the left side so the shifters are not pointing directly up.
damn now I am even confused but I hope I am right and I hope you guys can under stand this.
