fuel cell
Started by toyotajoe35, February 07, 2007, 08:26:40 PM
toyotajoe35
Does anyone know if you can run a stock fuel gauge with a fuel cell? if so tell me how. I also would like to know if i need o run all new fuel line for my fuel injection? Right now i have the stock fuel lines from the tank for my previous carburetor. I also need to know what fuel pump would be the best to use because i believe Toyota fuel injection requires 15psi of fuel pressure. thanks for all the help
toyotajoe35
should i move this post? i need help please.
dov'd85
not sure you can fit the stock gauge what does your cell look like? my buddy made his pump fit in a fuel cell but not the gauge?? not sure how that would work?  :dunno: pretty sure the tanks/ lines are not interchangable.. how big is your cell? got any pics?
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
toyotajoe35
No, Iwant to know how to use my stock sr5 fuel gauge with the sending unit in the fuel cell?
Talon84x4
Wouldn't it be easier to swap in a tank & lines from an efi?
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
toyotajoe35
No, because I want to balance out my truck. So I am puting dual batteries in my tool box in the middle of my truck and I want to move the fuel tank in the middle of my truck and lower to give me a lower center of gravity
unclejpl4x4
#6
don't know if they would work with other tanks    but your brand tank should have kits/options
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_758812_-1_10297
use a meter and hook it 2 the  fuel sender     move it from empty/full and    write down the ohms
if U have a factory sender and a fullcell sender    and then u will know if it will work
