Built 82' Truggy on 1 ton's....
Started by Shamb, February 05, 2007, 09:00:17 PM
Shamb
So i'm guaging interest in my rig, I have my eye on something that i've admired for years. I can't believe i'm actually putting it up for sale. Located in Northern California
1982' Toyota Pickup (Truggy)
Engine/Tranny/T-case:
22R w/ modded carb (it'll run on its side) was fully rebuild around 2 years ago and has only seen around 800-1000 miles since rebuild.
Fresh L-50 trans from Marlin that has no more then 500 miles on it, shifts perfect and have given me no problems.
Marlin Dual 2.28 t-cases (bringing the crawl ratio to around 108:1)
Front axle:
Chevy Dana 60 w/ Yukon 5.38's, Detroit locker and Full hydro steering w/ beefy steering arms, spencer 8" ram and a polished aluminum KBC resivor (bling!). Stub shafts have been upgraded to 35 spline with cryo'd u-joints and 35 spline warn premium hubs. New calipers, brake pads and steel braided brake lines
Rear axle:
14 bolt w/ rebuild brakes, steel braided brake lines, Yukon 5.38's and a Detroit locker.
Suspension:
BRAND NEW set of 16" Fox dual rate coilovers (actually ordered these today) for the front and a set of 16" Fox airshocks for the rear. Axles are linked w/ a custom 3 linked suspension.  1 1/2" links that are 1/2" thick DOM (never had a problem dragging them over rocks with no remorse!)
Custom .220" drive shafts front and rear that have been professionally made and balanced.
I can take this truck out on a 61" (5ft 1inch) ramp and not lift a tire.
Tires:
New 42" Iroks with 32 bolt steel beadlocks. 15" rims have been reverse cut for a 3" offset (gives it a good wide stance for stability)  :eyebrow:
Fuel system:
17 gallon polished aluminum RCI fuel tank with all new lines and new fuel pump.
Misc stuff:
Truck has full exo wrapped around it, set of full doors and half doors, rock lights, Tack on the dash, oil pressure and water temp guages installed w/ a Bearcat CB that works great. Honda accord seats that are comfortable. Heater works great for those winter runs. Fresh new gun metal grey paint job w/ ghost flames across the hood.
Registered for OFFROAD USE ONLY, yet all smog equipment is still on the truck and i'm sure it would still pass CA smog if it needed too.
This truck is seriously TURN KEY and needs absolutely NOTHING to wheel. ALL the parts on this truck have less then 3 trail runs on them. ALOT of blood and sweat went into building this truck through all the transitions its taken through out the years. It starts right up everytime without any problems what so ever. Picture of the truck can also be seen in the Nov/Dec issue of Crawl Mag.
Like I said in the begining... the only reason i'm even posting my rig is because there is something else I have had my eye on for years and finally it's for sale.
I'm probably missing some stuff so feel free to email or PM me with any further questions you may have.
Asking $15,000,  Add up the parts and labor.. you'll come to over $20k. Trust me I know  ;)
[email protected] or call me at (530) 870-3610
Thanks,
Shayne
rednk1980
Shamb
someone's gotta need a rig for the Jambo... or... ?
It'll take on anything you put it infront of!
Shamb
coils arrived today, these are included with the sale. They will be mounted on the truck this weekend.
LAGEN WAGON
Nice Rig. What could you of possibly found to justify replacing your Truggy?
85 EX Cab..30 Spline Longfields+Longs hub gears, 37" MTRs on crawlers..Marlin Hy steer.5.29 Detroit, Hydro, V-6 Tacoma Axle, 5.29 E-Locker, Marlin Duels, 4404's front, Chevies rear, Fully armored, Bobbed bed, Warn XDI 9000, Downey Header 2.5 Exhaust. Blah
85 runner 3" lift 30 spline longs/hub gears shave housing,trussed/armored. 4.88 detroit heims hysteer. V-6 rear axle 4.88 detroit. Marlin 4.7 case fully armored downey hi flow exhaust..The grocery getter.
Ramrod
damn thats crazy you barely even wheeled it yet. Too bad
To be honest though even though your price is totally legit for what you have into it nobody is gonna pay that for a built toyota.  If I were you id just take it off the market before you get talked down on price and loose even more money.  Not many people just have $15000 laying around to drop on a crawler
Shamb
QuoteNot many people just have $15000 laying around to drop on a crawler
This is true, that's why i'm advertising it everywere. Not just here..
Basically what it comes down too is if someone wants it bad enough. Esentially your buying something that not only will it go anywere you take it BUT you wont have to worry about breaking :pokinit: all the time either..
If it doesn't sale its no big deal, sucks.. but i'll just continue to build it  :)
I'm currently looking to purchase a buggy built by whitebrowithafro on PBB, buy far the nicest buggy I have ever seen. Been following the build since day one.
Shamb
Quote from: Hyena on February 08, 2007, 07:45:17 PM
damn, you haven't even rolled it yet!
haha.. this is true... I havn't even flopped it either.
BLACKDOG
Any luck on selling?
bump for a sweet rig :yupyup:
              -Ronald Reagan
Shamb
nah, no luck.. if Shane ends up selling his buggy this will come off the market.
Shamb
Whitebro's buggy is officially off the market.. so mine is as well!
I'll continue building it...
