stripped exhaust stud repair
Started by jimbo74, January 29, 2007, 09:21:50 PM
i was told by several members here that helicoils are worthless... and going the next size is impossible without major modifications
the issue is stripped exhaust studs on the rear of the exhaust header.....
duffil told me to locate a part called st-39. which i did, also got the tap for it... it is 7/16 - 14 on one side and 3/8 - 24 on the other side. i was told since the holes are already stripped that is basically like they are drilled out, and by using the 7/16 - 14 tap, i could get the stud in and with the 3/8 - 24 side would still fit through the exhaust manifold.
now the issue i am running into, is the stud has a little area between the 2 sides that is larger than the larger side of the stud. do i need to grind this down in order for the manifold to sit flush? or just thread it in there in the tapped hole and let it spread the itself into the head to accommodate it?
RustyToy
seams to me that the fat piece would fit into the really stripped part of the head so it would be flush with the head.   :headscratch:
#2
 :willynilly:
Willy Mammoth
I would grind it down being carfull not to under cut it or damage the threads.
I would have just used a helicoil or a time sert, but this should work too. Just remmember the threads are differant from all the rest.
mudmaster
Quote from: jimbo74 on January 29, 2007, 09:21:50 PM
I've always had good luck with Helicoils  :dunno:
Time to go wheelin!
Duffil
drill
tap
install
bolt on manifold
done
Quote from: Duffil on January 30, 2007, 01:54:44 PM
drill
tap
install
bolt on manifold
done
i thought you said i wouldnt have to drill it out, because the hole is smooth due to the fact the studs pulled out
Duffil
i dont remember much...if it's already that blown out, try running a tap down it.
meanokie
all you have to do is drill
tap
install
bolt on manifold
thats all all i did on mine
86 yoat 4runner SR5 32x11.50x15 on 15x10 rims,H4 conversion headlights, 4.88 diffs,4 inch trailmaster lift,slider bars
Duffil
Quote from: meanokie on January 30, 2007, 08:23:22 PM
tap
install
bolt on manifold
yeah, but you don't know up from down.  :ha_ha:
it is already blown out... its actually missing the 2 rearmost studs, and there are no threads left in either of those holes.....
Duffil
1. grow a sack
2. fill it with some nuts
3. tap that biatch!
4. bolt 'er up!
easy, right?!
Talon84x4
I tried already, it didn't work  :rivers: .
I've got one furthest forward stripped out and need a fix as well, all threads gone also.
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
mudmaster
When you helicoil a hole you are actually oversizing the hole then tapping it for the actual insert which will be the size you started when you are done. Any of this make sense?
Time to go wheelin!
Quote from: mudmaster on January 31, 2007, 08:10:01 AM
to  us YES,  to them,  apparently NOT
Duffil
Quote from: 79coyotefrg on January 31, 2007, 08:16:29 AM
It makes sense, Glen, I've just never had any luck Heli-Coiling exhaust stud holes.  I've used red loctite, sleeve retainer, they have always come out.  Studs, however, I have not had any issues with.  Of course, the engine that had those issues was cobbled together from about 10 different trucks, so I dunno.
no, it isnt that i dont know how to use helicoils, i am not using helicoils.
ok here is what i am going to do. im going to start tapping it, if i notice it doesnt fit and i need to drill it out, i will, if it fits im running it all the way in there
