Did your skyjacker springs make popping noises when they flex / shift?
So you could try that and run just a 1" block or put a 1" block deal between the frame and shackle hanger.
you mean a dropped shackle hanger
if you mean the 63 inch chevies sellthem to some one else, they are really thick and wont mix with toy leavesget a set of 2wd F150 extended cab springs, 88-94 they will give you 5 inches then use a longer shackle
Nope I thought it was 5inches at first (cause i had 5inch front springs) then realized it was probably closer to only 3 on my truck (sagged in the rear a lot) and maybe 1-2 on my 4runner. If it got any of a load then they would be almost flat, had nice flex though for sure. I have to run 3inch blocks on my runner to get the rear close to the front.
Here is a pic.
2wd F150 rears will give you that much lift in the rear of the runner? How much longer are they then the stock runner rears (1984 runner)
Noob here, how much more does my runner weight than the trucks!
thats a good ?? my 79 weighs 3500
hmm... I think my topic has been jacked...
Started by MiniSimp Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by TopStreet Parts For Sale
Started by 4XFlyin Parts For Sale
Started by GloNDark Parts Wanted
Started by megaphoneman Parts For Sale
