The way you want to set it up will get you the 7". I have that same set up. I don't like blocks but until I figure out something else I'm stuck with it! I'm thinking of pulling out one leaf in the front.
get a set of 2wd F150 extended cab springs, 88-94 they will give you 5 inches then use a longer shackle
My view, you gotta pay to play. 5" marlin rear springs would be the best start. If more was needed, some longer shackles and drop hangers could be made. Too much drop hanger could make for a rock anchor though.
if you mean the 63 inch chevies sellthem to some one else, they are really thick and wont mix with toy leavesget a set of 2wd F150 extended cab springs, 88-94 they will give you 5 inches then use a longer shackle
F150 extended cab springs?? Tell me more... How do they flex? How do they ride? How do you set them up?
WHy do you need 7 inches of lift anyway? I have 5 inches of lift with no body lift running 37s and I dont rub at all.
what do you have in the front? You could put your stock rears up front, and put chevies in the rear. That usually balances out pretty well, and you can adjust the packs to fit.I've got 4" out of my 63"s
5 inches my !!!I figure I got about 1 MAYBE 2 inches out of mine. They are out if exactly what you said and there is NO WAY you will get 5 inches. I had to run 3 inch blocks with 1-2" longer shackels in the rear to match the front which maybe has 5 inches...
REALLY?? i was sure you had said somewhere that you had that much lift thats where i was getting the info, besides building springs for other people
Yeah, those are the longer rear shackles with a drop down shackle. The longer shackle is a Chevy lowering shackle.
http://www.4x4grace.com/phpbb/viewtopic.php?t=4906&start=40for you guys running blocks these ubolt eliminaters can give you up to 1.5 inches lift its what im getting next with my chevies once i 4 link the front and scroll down the page to look at them
you would be fine with the chevies. you definitely dont need 7 inches of lift. i ran skyjackers too and they were no where near the actually height they said they were especially after being broken in. maybe more like a marlin 5 inch height wise.
Started by MiniSimp Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by TopStreet Parts For Sale
Started by 4XFlyin Parts For Sale
Started by GloNDark Parts Wanted
Started by megaphoneman Parts For Sale
