tranny ID help
Started by alfio, February 19, 2004, 11:12:02 PM
alfio
the lighter one came off an '89 4WD, the dirty one off an '85. do they fit the profile? are these interchangeable? tia
little a
#1
Im gonna go with the top one being a w-56.  From a efi truck.  The bottom one is confusing it looks to be a top shift case but the pic is pretty small, so it makes it tough.  Im gonna say its a g-58 with a chain drive case.  How many bolts are holding the rear output cover on?  That is the key.  If it is held on by 7 bolts it is a gear transfer, if 5 it is chain.  Also how many bolts hold the bellhousing to the trans?  Hope this helps ya out.
WT
84runner
Much better pics!  They are both W-56's with geared transfers.  The clean one is just forward shift.  yes they are both interchangable just have different shifter locations.
WT
Oh yea nice shoes! LOL
alfio
#5
so i can just swap in the "clean one" without any problems? what is forward shift? is there any difference between these two as far as reliability?
thanks, i love those shoes ;)
little a
Forward shift means that the transfer shifter is "forward" of the transfercase not dirrectly on top of the lowrange box.  They are the same trans you whouldnt have any prob's swapping them except maybe the shifters may need to be bent a little for clearance.  Instead of cutting another hole for the transfercase shifter you could just swap transfercases and use the plate that is on the 89 transfer to cover up the hole where the shifter origionally was.
WT
I just looked at the pic of the 89 tranny again you cant move the plate it has a differant bolt pattern.  But you could very easily make a plate to cover up the hole and use some rtv to seal it back up.
WT
supratruck
I was checiing out the pics. The clean tranny is a G-series. The rib pattern on the main case is different.
I give up if I cant keep my eyes straight enough I give up! :(
WT
alfio
if you guys don't know, i'm really in trouble
:dunno:
little a
alfio
Quote from: supratruck on February 21, 2004, 09:30:56 AM
what is the actual code then? will it still work in the '85? thanks
little a
I just checked the pics again that is a w-56. (I havent had any beer tonight LOL)  Yes irregardless it will work in the 85 without any issues.
WT
83 Toys
the dirty one is a W seires tranny
the clean one is a G seires tranny
They are interchangeable however
the W is much sronger and more reliable than the G due to the larger and wider bearings
the shifter holes will have to be redrilled (your floor will probly look like gears came flying threw it) :puke:
you could take the top shifting (dirty) case and bolt it to the clean one so you wont have to redrill the hole for the t-case shifter. but there is nothing to do for the trans shifter... you have to redrill it.
look at the pic of the cleen one... there is a black cast iron center section about 1 1/2" thick and on this trany there are 9 bolts holding the two housings to the center section
on the dirty one.... the center section is aluminum and there is 8 bolts holding the two housings to the center section
is the dirty one bad? why are you wanting to do the swap?
it would be more practical to replace a G with a W... that wold be an upgrade... but replaceing a W with a G is only benificial to have a truck that runs... say if you got a G for free and your W blew up you could limp your truck along with a G untill you could replace it with a W
i do not recomend replaceing a good W with a good G, your down gradeing.
just a wheeler with a little buget
Screw it this time I really give up!  Good luck with the swap.
WT
alfio
#15
Quote from: 83 Toys on February 22, 2004, 11:22:29 AM
this is good to know. thanks. i could probably sell the G and get the W rebuilt. how should i advertise the G (i.e. what year trucks came with that trans?).
little a
alfio
stone4x4
GOD MADE DIRT AND DIRT DON'T HURT
alfio
Quote from: stone4x4 on March 07, 2004, 10:46:00 AM
84-88 4x4 carb truck
really? that's strange. the guy i bought it from said it was off an '89. can't figure out why he would lie, maybe he didn't know (?)
thanks
little a
83 Toys
it could be an 89, depends on the month it was made. if it's a jan 89 it would look and have the same parts as an 88.
So if something Toyota is off buy a year, it's no big deal if it's off by two years.... the other guy dont know what he's talking about :slap: i'm not sure the month Toyota makes all there changes in but i can find out from the man himself if ya want
alfio
