If you rear locate the battery in the cab, make sure you use a Optima. It is a sealed battery & you wont get any fumes. You can mount it on it's side, upside down, how ever you want.Quick & easy.Custom,Make a stand off bracket out of tubing that welds to the side of the frame & bends up to the bottom of the battery hole {in your body} & weld a plate to the top of the tubing to make the tray, secure the battery to the tray. Make sure you cut the hole in the body to have clearance when the body flexes.If you make a box like 79coyotefrg says, make sure it has vents to let the fumes out.
BigMike made a mount for his under the bed up against the frame rail
Started by 94SRUNNER Toyota Pickup/4Runner Tech 1979-95
Started by Addicted Offroad Toyota Pickup/4Runner Tech 1979-95
Started by toyodaaddict Toyota Pickup/4Runner Tech 1979-95
Started by OTO Phil Suspension
Started by emsvitil Toyota Pickup/4Runner Tech 1979-95
