lift questions?
Started by jrock, January 10, 2007, 08:38:23 PM
jrock
all i want is about 2-3'' to fit 33x10.5 on an 85 pickup. all i find are 3'' and larger. i'd considered 53'' Chevys and relocating the rears up front to save money but i can't find info on the lift ht. and it looks a litttle extreem for what i do. but i have thought of using All-pro 5'' springs and doing an axle over. any thoughts?
8D3TOY
A 3" lift like Downey's is not that much $ and it wont lift the truck really high like the 5" All Pro. With 3" you can fit 33's nicely.  Axle over? Not real sure what you mean.
jrock
axle over: axles on top of the leaf springs not under.
FIREBALL
You can do a combination of add-a-leafs and longer shackles. Cheap and not too much lift. Maybe not optimal as far as articulation etc. but for mild wheelin would be fine.
The other option if you can fab, is cut and re-locate your spring hangers down a couple of inches and build longer shackles. Your spring rate and ride will be basicaly the same just located lower.
eightyfive
this isn't the tech section...
1985 TOYOTA 4RUNNER
Quote from: eightyfive on January 10, 2007, 09:58:28 PM
Nope, it's project research, so his questions seem ok to me :dunno:
Quote from: jkief86 on January 10, 2007, 08:55:10 PM
This will give you about 5.5" of DROP, not lift!
The beauty of putting rears up front is you can dial in the exact lift you want.  You don't just automatically get 4 or 5" lift, it's all in how you set the packs up.  The chevies in the rear will be a little harder to keep the low lift though.  If you're trying to do it on the cheap, I'd look into something like downey's full length add a leaf, or look into making your own, then use a mild 1" lift block.  The rears on my 91 2wd have a very thick and long overload, which will aid a little in lifting and keep your springs from going negetive.
If you're dead set on going chevies/fords in the rear, you could always look into frenching the hangers, should help limit the lift a little.
randito
I've heard good things about Old Man Emu springs and lift kits.  Kinda pricey though.  Let us know what you decide and how it works, I'm interested in something similar for my '85.
jrock
so to fit 33x10.5s like BF Allterrains what mild stuff could i do other than lifts.
and can you give me a link or post that shows how to make leaf packs.
sorry if i'm going into tech, but just doing some reaserch.
jrock
do you think adding an all-pro hanger and drop shackles in the front, then blocks in the back would work.
skid
Quote from: jkief86 on January 11, 2007, 03:39:25 PM
Or Marlin's hanger and shackles.
Yes, that would be a cheap way while maintaining close to stock castor specs.
Keep in mind some fab skill would be required, or pay some one to install the hanger.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
jrock
anyone done this? and will stock everthing still work, for now?
yeshwa
I fit 32 11.50 on my 82 when it was stock and still had a little room, no rubbing or anything.  so you could probably get away with a 1" body lift, i got one for $60 from sky manufacturing, and some extended shackles.  Currently i have a 3" pro comp lift that works fine with 33 12.50 and doesn't sit to high but it also doesn't flex well :-\ but whatevs.  good luck on your lifting quest
82' pickup, bobbed, custom canvas top, rollin on 33s with 4.88s and lockrite up front, aussie in the rear
yotakid88
I think there is a 3" lift on 4wd parts web site
got low range
95/91 pickup, 3in tuff country lif and a bunch of marlins stuff.
i would stay away from anything 4wp sells....... they are way overpriced, and dont stand behind any of their products.... their so called technicians know less than the guys that work at the local tire shops.....
Quote from: yotakid88 on January 11, 2007, 06:59:09 PM
all the lifts they sell for toyotas are crap
FIREBALL
BUY FROM MARLIN!!!! You get support, like this website and from employees that actually use what they sell.
skid
#16
Trail -gear(bite my tongue) sells a 3", most likely needs longer shackles too.  A friend with the 5" isn't impressed.  They told him 6 month's of wheeling before the springs would s and sag.  His made it 3 months.  Might last on something that doesn't get stretch out.
Another option requiring fab work.  French in a new hanger, high than stock?  Raise the shackle tube and mod the cab mount to work.  This could take a inch or two out of lift springs.
Quote from: skid on January 11, 2007, 07:27:28 PM
who told him that?
So does all pro, and I'd much rather put food on their table, but that's just me (and probably some other people too)!  Seems like marlin sold a 3" spring when I first joined this forum, but I haven't seen any info on it in quite some time.
skid
Quote from: Dirt Toy Boy on January 11, 2007, 07:37:38 PM
who told him that?
Not sure who he talk to at Trail-gear.   But they did sell him some "heavy duty" ones now.
Quote from: kneedownnate on January 11, 2007, 07:39:54 PM
All pro's 3" is a super soft rate compared to their other springs. I thought for 3000lbs buggy types. I'm guessing it wouldn't be suited well for the street on a pick up.
Quote from: skid on January 11, 2007, 07:45:14 PM
well that would make sense if he had a really really heavy truck (v6/8 or exo/extra weight) sorry :offtopic:
jrock
do you think adding a Marlin hanger and drop shackles in the front, then blocks in the back would work.
skid
Hanger is a 1" drop, combined with a 5.5" shackle should net about 1.5" lift.  Stock steering should be fine.  Long travel wreaks havoc on J-arms.     Crossover steering's recommended for reliability and minimize bump steer.  A little more spring lift is usually need to clear crossover though. Might not even have to lengthen the front driveshaft. If the brake lines are too short,  lower the mounts on the frame.
What are you planning to use the truck for?  Future plans?
boggerunner
u could call up Alcan Spring and get some 3" lift leaves and be done with it, they can make any height leaf u want.
