Author Topic: Full Floater  (Read 2339 times)
toolman
  • Male Posts: 194
  • Member since Apr '06
Full Floater
« on: Jan 09, 2007, 09:27:00 AM »
Who runs a full float rear? And is it worth the trouble and where can I find a kit?
Thanks
'82 yota work in progress
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
8D3TOY
  • Turtle Points: 5
  • Member since May '05
Re: Full Floater
« Reply #1 on: Jan 09, 2007, 10:43:57 AM »
There is a post on here about it and I think a guy on Pirate built one, I have thought about it but every factory FF I find is big $$.
E-9
  • Turtle Points: 79
  • Member since Apr '03
  • I love Marlin Crawler!
Re: Full Floater
« Reply #2 on: Jan 09, 2007, 10:53:38 AM »
Front Range sells a kit for this. I run theirs and am pleased.
toolman [OP]
  • Male Posts: 194
Re: Full Floater
« Reply #3 on: Jan 09, 2007, 11:29:03 AM »
WOW! those kits are high! May just do without for a while.
Thanks
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
Re: Full Floater
« Reply #4 on: Jan 09, 2007, 05:39:09 PM »
They're cool, but if you're not breaking rear axles then it's probably not worth the money. If you know a machinest then you could build your own fairly easy and with factory toyota parts except for the custom axles.
toolman [OP]
  • Male Posts: 194
Re: Full Floater
« Reply #5 on: Jan 09, 2007, 06:02:05 PM »
Yeah I may just convert to disc brakes and go with some stronger axles.
Thanks
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
FIREBALL
Re: Full Floater
« Reply #6 on: Jan 10, 2007, 09:04:42 PM »
What are you planning for your truck? With your current setup axles and discs for the rear are way overkill. I've run 38's and never broke a rear axle and disc's work well, but i've still been able to lock up the rears with late model drums.
Your dollars might be better spent on upgrading the front axles that tend to be a weaer link than the rear.
toolman [OP]
  • Male Posts: 194
Re: Full Floater
« Reply #7 on: Jan 11, 2007, 04:51:55 AM »
Well Ive already thought of that. I rebuilt the front axles last summer, I didnt have the money for xover steering at the time so I am planning to get that as well. As for overkill on the disc brakes and axles for the rear, I kinda thought that was the point? Any way thats kinda what I had in mind. Most of what I will be doing with the truck won't be that hardcore wheeling like some of you guys do. Just not any good places around here for that kinda stuff.
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
AaronB
  • Turtle Points: 287
  • Male Posts: 2,452
  • Member since Nov '05
  • Wish I Was Crawling
Re: Full Floater
« Reply #8 on: Jan 11, 2007, 05:17:10 AM »
I think the rear axle on fj60's is a full floater
FIREBALL
Re: Full Floater
« Reply #9 on: Jan 11, 2007, 08:10:16 AM »
Overkill is, I guess, is what we are looking for. My point is that there are many other things, IMO, that you would benefit more from before you got to the point where you would need rear discs or a FF.
As far as stopping power, you could benefit more from upgrading your front brakes to vented rotors like the IFS trucks came with. You'd have better stopping power and better cooling with less likelyhood of warping rotors. There are several ways of getting the vented rotors, like using Landcruiser discs or using ifs hubs and rotors witch will also gain you 3" of front end width. Then you could upgrade to an '86 or newer rear that is also 3" wider and has larger drums than the earlier trucks.
Birfields are also always a worry so upgrading to Longfields would also be a very good investment.
Just some suggestions as alternatives to high dollar FF, disc kits.
E-9
  • Turtle Points: 79
Re: Full Floater
« Reply #10 on: Jan 11, 2007, 09:20:25 AM »
I agree with the previous post. The full floater would be the last thing i would do. I did it last with my truck. I had all the exrtra parts on hand, so no expense about the cost of the coversion. I ran my stock rear brakes until they litterally seized up from mud and grit.( about 3 years) I live in NC, so their is plenty of wet weather. The only advantages to the floater is the ability to run locking hubs on the rear, if you choose to do so, (I broke hub splines in twice on the rear) and now run flanges, and you can also pull a broken axle and keep moving along.
toolman [OP]
  • Male Posts: 194
Re: Full Floater
« Reply #11 on: Jan 11, 2007, 09:38:42 AM »
Alot of good points. Thanks. Yeah I think it would be one of the last things I would do. I really would rather put the vented rotors up front first. I have alot of things I want to do to this truck just gonna take some time. Thats the good part, I can leave it sit if I don't have the money, doesnt cost a dime to leave in the driveway.
Thanks
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
Last post Dec 08, 2006, 02:12:17 PM
by 8D3TOY
Last post Sep 29, 2006, 09:31:37 AM
by cougarfreak
Last post Mar 17, 2007, 12:37:16 PM
by Toy1
Last post Jan 07, 2008, 10:20:11 PM
by Thomas P
Last post Apr 15, 2008, 06:12:02 AM
by crawlerdan
