2wd- dual case adapter
Started by gumbom, February 16, 2004, 12:09:33 AM
gumbom
well this is the second input shaft ive broken on the rear case,:smack:
im using one of the early 2wd tailshafthousings with a plate to mate the rear case to the front one, it uses a sleve to mate the two cases shafts together
however i want to have a 23 splined case for the rear and keep the 21 splined front case so id need a female splined sleve that goes from 21 to 23 splines, does marlin or anyone else make this
If what I think you are thinking of is the same as you are thinking of then yes.  Marlin has a adapter for using a 23 spline in the rear case.
WT
gumbom
awsome could u post the link? i tryed searching and couldnt find it
Marlin
Yes, I have been making a 21 spline input to a 23 spline rear case for years now. It is called a MC07-K23 (kit), or MC07-U23 (unit). You can find these on my web page or call for more info.
MC
