HEATER NOT WORKING
Started by yotamckimboy4x4, January 05, 2007, 10:37:10 AM
yotamckimboy4x4
Ya last night i went to jump in my truck when i got off and the darn heat wouldnt work. i checked the fuses and they were all good. i was thinkn the only other thing it could be would be the relay. wat do yall think?
"We ride together, We die together, YOTABOYS FOR LIFE"    85 toy pickup 5 inch springs 2inch body lift, 36" IROKS, custom front bumper
"HOLD ON TIGHT"
CTENG in KS
You mean no hot  air, or no air blowing at all?
yotamckimboy4x4
It isnt blowing air at all. well i take that back the only time it is blowing air is when im driving down the road and its takin heat from the engine
"HOLD ON TIGHT"
CTENG in KS
If you have checked all the fuses and stuff, maybe pull the heater controls portion of the dash and see if the switch is functioning?  Maybe a wire come loose or something?
punkrock crawler
Also check the relay on the side of the heater unit under your dash. If that has gone out you will have no power to the blower motor. You can get a new one at the parts store for only 15-25 bucks.
Dying to live and living to die!
1983 Hilux
3" suspension lift, Marlin L52 transmission, Marlin ultimatecase 4.70, Marlin 1200 Clutch, 30" tires, Spraypaint exterior, Webber carb.
2006 Tacoma 4x4
rockcrawlinredneck
Or you could check the other 12 post's that have been made in the last 3 week's for more answer's. They should be easy to find the titles are almost the exact same as your's.
Kevin
