0 Members and 10 Guests are viewing this topic.
what if i dont have that ground on our plugs? almost all of of outlets in the house are 2 prongs..... how can i make these all 3 prong, safely? it appears that some plugs are the gfci plugs with the buttons and a couple others throughout the house are also a 3 rong outlet...... how can i verify these are indeed, safe.... and also.... can i make all the otehr 2 prongs into 3 prongs, or would new wiring need to be run or what?
T.V. looks great man. Good Job.
Today's little house project was installing a spring hinge on the bathroom door so I don't have to look at the bathroom from the kitchen when people don't swing the door closed. It's set so that it doesn't actually close the door, just keeps it from being wide open. Much improved!
You can check if your box is grounded by using a volt meter . one side to the black wire and the other lead to the box, if you get 120v then the box is grounded.
Started by BigMike Project Research and Build-Ups
Started by AaronB RC Rock Crawler Tech
Started by bebe Rubicon
Started by sparkys83yota Welding Tech
Started by YotaRick New Member Check-In!
