the compression should be no less than 100psi. that is really on the low side.
and valve seals arent going to cause a noticeable loss of compression, it WILL cause smoke from burning oil after you idle a few minutesdo a compression check and report back the numbers
pressure in the crankcase is sometimes referred to as blowby. with the truck running pull the hose just off just behind the oil cap. you should get just a little air coming out of the valve cover. to much would be if there is oil coming out with it or you have a lot of pressure when you take the hose off. if you do have alot of pressure. i would make sure you have no resrictions in the hose going the pcv valve. to check it pull the pcv valve out with it still hooked to the itntake, start the engine and there should be vacuum at the valve. compression is low but in the real world the truck will run on those numbers. if you are using that much oil you should easily be able to find out where it is going.
Started by Weldo « 1 2 » Engine
Started by nrgwar Toyota Pickup/4Runner Tech 1979-95
Started by mmml4 Toyota Pickup/4Runner Tech 1979-95
Started by weirdtimes_7 Toyota Pickup/4Runner Tech 1979-95
Started by hotrod Engine
