Author Topic: Crossmember nut broke...fixes?  (Read 2864 times)
mjos
  • Member since Dec '06
« on: Dec 26, 2006, 03:21:58 PM »
While I was taking out my 4 bolts that hold the crossmember under the xfer case in, one of the nuts inside the framebroke loose.  Joy!  I had to use a sawsall and cut the bolt off.  Now, what would be the best fix?  Just use 3 bolts?  Thread in a larger self tapper?
Got my Marlin 4.7case today  :clap:
05' 4R V8 Sport, Toytec Ultimate 3", 33's, Sliders
*FFC*
  • Platinum Turtle Award
  • Internet Lassies
  • Turtle Points: 11
  • Female Posts: 8,265
  • Member since May '04
  • ~*Moderator*~
    • Buy me some coffee
Re: Crossmember nut broke...fixes?
« Reply #1 on: Dec 26, 2006, 03:27:56 PM »
Just drill it out and use some grade 8 bolts/nuts/washers from OSH :thumbs:
mjos [OP]
« Reply #2 on: Dec 26, 2006, 03:29:41 PM »
Hmm..so drill all the way through the top of the frame too and run a long Grade 8 through?
*FFC*
  • Internet Lassies
  • Turtle Points: 11
  • ~*Moderator*~
« Reply #3 on: Dec 26, 2006, 03:33:13 PM »
Is your frame open or closed? I have an open frame and was able to do it just through the bottom part.
kajo4x4toy
  • Turtle Points: 58
  • Male Posts: 37
  • Member since Jan '03
« Reply #4 on: Dec 26, 2006, 03:36:55 PM »
I had the same thing happen to my old 4Runner. I ended up running 3 bolts on that side for about three years with no issues. It might not have been the "best" solution bt it never caused any problems.
1985 exo-runner
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #5 on: Dec 26, 2006, 05:25:28 PM »
Center punch the bolt & start with a small drill bit & work your way up to a larger drill bit. Be careful not to damage the threads that are in the frame. Spary WD40 or what ever you have to lube the treads. Drill it upto 1/4" & try using an easy out or a drill bit that drills left hand.
Scratch that, I miss read. Now is the time to replace you x-member with one that bolts to the back of the transfer case.
« Last Edit: Dec 26, 2006, 05:29:58 PM by Tallchevy350 »
87 4Runner redo
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Dec 26, 2006, 05:34:27 PM »
am i the only one that understood his ??
dude,  just run 3 bolts on that side
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #7 on: Dec 26, 2006, 05:35:07 PM »
I take it the tacks on the nut to frame broke so the nut/bolt were just spining. I dont belive you will ever get a drill bit to start unless you could hold the nut from spinning.  3 bolts should be all you need to keep everything together. If you were to use a self taping bolt it wouldnt be contacting much meat with the nut gone from the inside of the frame.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #8 on: Dec 26, 2006, 05:40:51 PM »
just run 3.  it isn't going to hurt anything.  most toyota's i see either have 1 or even 2 bolts missing per side.
mjos [OP]
« Reply #9 on: Dec 26, 2006, 07:07:50 PM »
3 it is then. :)
olivedrab85
  • Turtle Points: 102
  • Male Posts: 548
  • Member since Jul '05
  • "Ghost ride the whip"
« Reply #10 on: Dec 26, 2006, 07:17:32 PM »
I'm rockin 3 on the drivers side no probs yet.
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #11 on: Dec 26, 2006, 08:06:19 PM »
Run three.
:thumbs:
              -Ronald Reagan
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #12 on: Dec 26, 2006, 09:27:58 PM »
yea im running three as well... busted one off and works just fine...
if you feel you need 4 then get to drilling/taping.
Last post Jan 05, 2003, 10:33:38 AM
by slowpoksdrvr
Last post Feb 17, 2004, 10:31:29 PM
by 84runner
Last post Jan 05, 2009, 05:29:46 AM
by red
Last post Sep 12, 2013, 11:47:29 AM
by ssicoffroadshop
Last post Sep 26, 2012, 07:14:06 PM
by BigMike
