1987 FJ60 rear disk brake
Started by Pacific Swell, December 15, 2006, 05:20:26 PM
Pacific Swell
Help!  :dunno: I just replaced my rear drum brakes with disk brakes. Problem is my parking brake is rendered useless.
Anyone out there know what to do? I ordered my conversion disk kit from Specter's Off Road. I called them to ask their help but they just told me to check on GM parts and that I'll need to modify things.
I'm no techi  :think: and going nuts looking for a solution to this problem. I've searched online without any luck.
Please help.
Thanks,
Pacific Swell
greenfox
The only way to go would be to put a E brake on back of the t/c but you have to put a new shaft in the transmision to make it work.
67fj45lpd
73fj40
74fj40soa
97fzj80
CruzrDave
Downey Off-Road has early GM calipers with a factory e-brake bracket. The bracket pulls from a different angel so you will need Downey's e-brake cable kit. We just installed a FJ60 axle on a FJ40 using this kit a few months ago. Worked out great.
Taking back America, one part at a time! :madeinusa:
denis
Some late 45 series had a split case with a drum park brake, I would go for a line lock myself or a disk park brake behind the t/case if you're worried about the redundancy part of the e-brake concept.
collecting toyotas since 2002
'71MS75 '73MS75 '75BJ40 '79FJ55 '80BJ40 '83LN46 '86LN65 '90HDJ80 '92LN85 '96KZJ70 '96LN108
