taco axle question
Started by max, February 10, 2004, 06:37:30 PM
max
I want to do a tacoma solid axle swap.  I want to use a rear tacoma axle in the front.  If you turn the axle around it will be runing in reverse due to the fact that the front and rear drive shafts are connected and turn in oposite directions.  So you need to flip the axle and turn it around.  (Breather drain and fill plug would have to be relocated).  Now what am I missing?  My question is can the axle be mounted up side down what is stoping me.  Axles are ran in reverse all the time, WHEN YOU DRIVE IN REVERSE.  Would it be safe to drive it like this or would the pinion gears have to be reversed?  Please everyone give me you opinion.  If it works you could use axle with electric locker, 2 four 1!
reklund5
wouldn't it need to turn...like left to right?
Marlin
#2
Yes this would work as long as you rotated the axle and flipped it 180 degrees HOWEVER,
Need to add knuckles, rotors, steering ect.....
The punkin would be in the middle-front d-shaft would be at a 45 degree angle.
Because the rear punkin housing was not designed to be a high pinion, how is oil going to get to the small pinion bearing? A reverse rotation factory high pinion diff, uses a reverse cut gear that would place the pinion on the oppisite side of the ring gear so that the oil is thrown at the pinion instead of slinging it away in your design.
I hope this makes sence :sleeping:
What you are asking about, is beening done very well in rock crawling rigs in Pro Rocks ect., but they are going very slow and most are using a ford 9" dropout run upside down reversed!!!
It would not last if run at high speeds on the road. The pinion bearing would burn up from lack of oil.
max
Yeah makes sence, and I was thinking about it more after I posted and remembered the diff. is in the middle of the rear axle not the side!  well guess I could go with the dana 44 axle like everyone else is.  Marlin will your hi crossover steering kit work with tacoma solid axle swap?
Marlin
As long as you use a toy axle, it will work.
I knew you would realize your oversight :hammer:
I hate it when I forget the simple things-----------
MC
84runner
mr4x42u
Just use a waggy 44..seems to be the most popular..
WAAAAHHOOOOO !!!! I CANT TURN!!!!!LOOOOK  OOUUUTTT!!! :driving:
Steering is good.. :yupyup:
84runner
Now on that waggy 44 do you have to cut it down and move the driver side perch in to match the factory toyota width between the springs?
max
Is there any toyota solid front axle that can be put on the tacoma?
yotaboy79
any front axle from a 79 to 85 should work u mite have to move the spring pertches, but thats easy, an 84 or 85 axle would be the best to use because of strength, i hope that helps
max
The diff is on the drivers side on the tacoma and the others is on the right.  I would like to see the joints i would need to route my drive shaft down across the tranny around the bellhousing up into the cab around the brake pedal and back down to the 3rd member, and have no vibrations!  So is there a toyota axle with diff on drivers side?
yotaboy79
i dont know i thuaght that the ifs driveline was in themiddle of the truck i dont think that there is  solid axle from toyota that has the pumpkin on the drivers side, call currie interprises they could probably make u an axle, but it wont be cheap
max
yeah well i feel like an ass, i am at Marlins site and didn't know that he has a adaptor to use old style transfer case for passenger side out put to be used with tacoma SAS.  I want to see some pictures of the shifters is someones truck after installing dual case setup, anyone know of any pics.
yotaboy79
ahh no biggy, there should be some pics in the teck section or in the project tthingymababer
