Check out this '78 Builder
Started by Marlin, December 11, 2006, 09:11:04 PM
Marlin
Wow!  There are only 2 things that would make that truck cooler, 1: 4wuild buildup, or 2: if they'd put a dually rear on it.
46&2
AaronB
BUDDERS
Wow Marlin, good find   :thumbs:  It should make someone a good project, but I have too many right now and not enough room to work on the ones I already have.
