tranny help
Started by yotaboy79, February 08, 2004, 03:18:19 PM
yotaboy79
i just blew up my stock L43 4 speed and im having trouble finding a replacement at junk yards, and i was wondering if toyota made any other trannys that would bolt up with no modifacation, the tranny needs to go in my 79 yota 4x4 with the 20r, thank you for any help
#1
If I remember right any trans from 79-83 4x4 will bolt right in.  Heck sometime this month Ill be taking the 4 speed out and putting a w56 in its place.  Your welcome to it.
Thumper
Hey i have a brand new rebuilt tranny its a 4 speed its got all new berrings and syncros, installed by a certified toyota mechanic and it works great its only got 10 miles sence i rebult it too make shure it worked good then swaped in a 5 speed.
i want 275.00 for it becuase thats what it cost me too rebuild.
Marlin
Quote from: yotaboy79 on February 08, 2004, 03:18:19 PM
Because your 79-80' L43 is a side shifting trans that has a adjustable clutch fork push rod, there is no other trans that is a direct bolt in.
Your trans is 21 1/2" long so a 81-83' L45, L50, OR L52 trans would also fit, but there is a lot of changes that would have to be done.
Thumper
hey my 4 speed is an L43 too side shifter its got new berrings syncros and i forgot too tell u its got all new shifter forks in it because myne were broke when i got it, the gears look great on the inside and it works great, if no one wants it ill prob just put it in another project later on.
275 is all i want for it because thats what it cost for parts for rebuild and was rebuilt by certified toyota mechanic, so u know its good. can post pics if u need them.
yotaboy79
#5
sorry thumper i dont have the money for the shipping bill, oklahoma to oregon? plus i  found one here in oregon, thanks any way
thanks for the info marlin :bowdown:  :beerchug:
I would suppose you would need the clutch slave, pressure line, tranny and shifter.  All that can be found easily enough, I hit the wrecking yard today and paid a visit to the yota's more than enough to get you on the road REAL cheap if ya got the time.
yotaboy79
i talked to a friend with a 1980 yota he had a rebuilt one out of his truck that im getting for $150 tomarrow
yotaboy79
what i did was i blew up the bearing on the imput shaft
and prolly messed up every thing else inside the tranny. the input shaft has 1/4 in of play, the clutch and everything else is fine
Cool sounds like ya got it figured out easily enough Good Luck
WT
Thumper
Hey no prob i know what u mean about the shipping, good luck on ur new one comeing sounds like a heck of a deal.
