Will 2-way Walkie Talkie work with CB?
Started by 82rustbeast, November 18, 2006, 08:10:50 PM
82rustbeast
Is there a way to get my two-way walkie talkies to be picked up on my cb frequencies?
Skybill
If your 2 Way walkie-talkies are on the CB band then the frequencies would be the same and you could use them with each other.
If your walkie-talkies are the FRS/GMRS type then the answer is no.
Here's why;
1 - The CB is AM (Amplitude Modulation) and the FRS/GMRS radios are FM (Frequency Modulation).  The easiest way to think about this would be as if 2 people speaking different languages were trying to talk to each other.
2 - The frequency of the CB Channels are; 26.965 MHz (CH-1) to 27.405 MHz. (CH-40).  The GMRS frequencies are; 462.550 MHz. to 467.725 MHz. The FRS frequencies are; 462.5625 MHz. to 467.7125 MHz. The FRS frequencies are sandwiched in between the GMRS channels.
The difference in frequency would make them incompatible with the CB.
A couple of helpful links;
http://support.radioshack.com/support_tutorials/communications/67159.htm#CB1
http://ba-marc.org/writeups/gmrs-frs-freq.htm
Hope this helps.
SkyBill
Mega Baby Huey
I'VE HEARD THERE'S A WAY...BUT I NEVER GOT IT TO WORK!
The Art of Flying is Actually Quite Simple! You Just Have to Throw Yourself at the Ground and Miss!!!                                   All This Global Warming is Wearing Out My Snow Shovel!!!                        Paved Roads: Just Another Example of Useless Government Spending!                                          Toyota. Moving forward... even if you don't want to...
My Old Toy
