Topar's build
Started by topar, November 18, 2006, 08:06:22 AM
topar
Intermediate shaft in with locking plate & gear identification plate.
topar
Looks like everything is in.   :crossed:
topar
Comparing it to my other case to see if it looked right.  Seems good.   :thumbs:
topar
Got the rear output on & checked by hand that everything shifted and spun correctly.  Seems good.
topar
Now I just have to wait for my buddy Zac to finish welding up the aluminum adaptor & a warm day to sit out in the driveway & put it all back in.  It wont be this week its going to rain all day today & tomorrow.   :rain:
topar
Dropped off the old T case to Zac today so he can copy the bolt pattern on to the newly repaired adaptor.
topar
Finished the linkage for the new shift rails.
Got a movie for Cole at Northern Hardware cost a whopping 50 cent.
Hopefully have the adaptor soon & get this thing running again.  :crossed:
topar
Watched that movie with Cole before I came into work tonight.  You know there was a reason it was 50 cents.  Bad doesn't cover it.   :outtahere:
topar
Zac's new truck, 79 Long Bed.
topar
Got my adaptor back from Zac.
Not bad for a free-be.  a lot better than I could do.  I was a welder in the Navy for 4 years & never could weld aluminum for pooh.  :hammerhead:
topar
Bolted it up to the transfer case.
I will hopefully put it back under the truck next month.  I finish midnight shift this week.  Then we are taking our son Cole to the Atlanta aquarium for his 5th birthday.  Then a lot of hours at work the following week.  So I hope to have the truck back together in about 3 weeks.   :crossed:
twistedtoy92
that adapter looks kinda scary.... whats the specs??
topar
Its a factory adaptor that's been put back together.  They are weak from the factory & it broke into several pieces a few years ago.  A buddy of mine welded it back together for me if I get just a few trips out of it that's okay with me.  Hopefully I will be changing it out.  I would like to go with a NP 203 then the Dana 20.
topar
Started installing the transfer case in the truck today.  Here is the adaptor in place.
topar
Transfer case, cross member & rear drive shaft in.
topar
Pretty much the same picture as the last one.  The red tape is to remind me that I do not like the way it bolts into the aluminum adaptor so tomorrow I will put in longer bolts go through the top & place nuts on top.
Then today was my day off of work so naturally I had to go in to work for 6 hours.  Hopefully finish it tomorrow & maybe  :crossed: have it move under its own power for the first time in about 4 years.  :crossed:  :crossed:
topar
Did not work on it today.  Had to work on the Dodge instead.  Also mowed the grass in the rain.  :willynilly:
topar
Got the new linksfinished today.  This is a pic. of one of them.  It stormed here all day plus my newly installed slidding glass door leaked so I spent most of the day attempting to stop the leak in the rain & moping.  Hopefully I will have the links in soon.
topar
Drained all the old fuel out, replaced both fuel filters.  I have an Elderbrock off road carb so I took the top of it off & found out why the truck would not start.  Damn ethanol fuel looked like honey I could actually pick it up out of the fuel bowls with my hands.  Once all that was cleaned up with a lot of carb cleaner the truck fired right up.   :clap2:  Now just have to finish putting my links in & adjusting them then off to test drive it!   :crossed:
topar
Had to post this picture, that's my Dodge.
topar
Finished bolting everything up, then drove it around the house did not hear anything from the T case & everything felt good.  After the truck ran a few times it seemed to start having fuel problems so I took the carb off & am tearing it completely down to make sure everything is clean.  Hopefully it will run great then.   :crossed:
topar
In Roanoke, Va. they have a truck show every year called Touch a Truck.  It is all kinds of work & play trucks plus boats & helicopters.  It is a free show that families go to & the kids can get into & on the vehicles.  This year it is Saturday 7/30/11, I am registered for this event so I actually have a dead line to meet.  Hopefully that Sunday I will take Cole (my son) on his first 4x4 trip.
topar
Made it to the truck show.
topar
topar
topar
Cole on the zip line.
Ride Cole ride!
topar
topar
topar
& on Sunday Cole went on his first 4 wheeling trip.  Potts Mnt.
topar
Cole, Andy & Zac.  Also Andys first wheeling trip.
Cole, Zac & I.
