79 toyota Sending unit
Started by linkpin, February 04, 2004, 09:20:23 AM
linkpin
I have a 1979 pickup that needs a gas tank sending unit and also the other unit on the tank where the fuel line connects I went to the local parts store and there computer and books do not go back that far. Is this a part I have to get thru toyota.
95TacoTruck
Just guessing but just about everything that I needed for my 83 seemed to be a dealer part so I would imagine something like that is.
95 Tacoma Extra cab, many mods to come........
84runner
My brother just replaced the fuel pump in his 79 and had to go to the dealer
Marlin
New from the dealer, or used in a tank somewhere.....
linkpin
Thanks. Anyone have a good used sender? If not I guess I will go to the dealer and pick one up.
84runner
Hit up the wrecking yards and the dismantlers
