how do i hook up an aftermarket tachometer.
Started by yotadork83, November 11, 2006, 02:22:26 PM
yotadork83
i am trying to hook up a tach to this type of coil and i dont know which wire to tire into. to make it work.
yotas 4 life homie!
KYOTA
either 2 on the right in your pic.  I used the one in the middle but the one on the right works too
crawlerdan
Quote from: yotadork83 on November 11, 2006, 02:22:26 PM
there is a plug on the side closest to the firewall that is the tach lead, if you dont have a factory tach, use this, if you dom tap into that same plug
other than that-black goes to ground, and white goes to switched power with the red wire as well
