replacement rear crossmember?
Started by Brandon, February 02, 2004, 10:22:07 AM
Brandon
mine is looking like one big booger, welded so many times it is nearly all weld. Time to chop it off and replace it with something, anyone done this? I don't even run a track bar anymore and it has a complete crack across both sides at the top and one in the middle (just welded em yesterday, again).
I am going to ditch my flatbed and build one welded to the frame to stiffen it up, hopefully that will help.
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Toyoballs
Your talking about the horse shoe cross menber right?
I wondered about the strength of it cause I'm in the process of starting to fab an anti-axle wrap bar  :_order: I thought about reiforcing it just in case; now after hearing about yours  ::) I'll be a beefing it up :flamer:
There was a truck I just saw with a flat tranny cross member on it - pushing his tranny up over 3", he cut out the tranny tunnel in the floor board for clearance. I did like his new rear cross member as it was now square tubing flat across frame rail to frame rail.  Nothing hung below side frame rails :yupyup:
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
