lift question.
Started by CaliZuki, October 23, 2006, 09:56:46 PM
CaliZuki
hello, i have a 82 toyota pu. heres what imthinking. tell me if this will work like i think. rears up front with 2 springs added from a chevy pack. and a m/c 5inch rear lift kit. will this sit close to leavl? or would i need to add moresprings up front?  how many springs added is to much? i want to run 35 - 37 inch tires.. what do you all think?
if you use 2wd  chevy S10 rear springs  then  you'll be ok,  dont try and use those thickass  63  leaves cut down  :shake:
CaliZuki
what if i used some springs from the front pack. rears up front and use front springs for add a leaf. hw well would this work?
Quote from: CenCal on October 24, 2006, 08:18:25 PM
it wouldnt,  the front springs  have very little flex  or lift
the first thing i do when building a set of hybrid springs  is  throw  all but the top 2 leaves  of the front packs  in the dumpster
Hottrod81
Just save your money and buy some 5" springs for the front.  It pays off to do it right the first time around.
CaliZuki
the reason i ask is. because i have alot of truck springs at my house. so i thought i could build a set of springs wheel them for about a year or so then buy some mc 5in springs. i hear that hybrid springs can be very flexy and a nice lift. for cheap.what would be the best springs to use for the pack? chevy, ford, s10 springs? i have chevys ( all but s10) fords and a set of waggy springs.
my favorites  are the 2wd f150's
