put a solid axle on front of the daily driver...
Started by booger weldz, January 25, 2004, 09:17:03 PM
booger weldz
my one year old son broke a cv joint idling up a hill from our favorite campin/fishin spot (223:1) so i saw it as foreshadowing to the following event :thumbs:
booger weldz
hes not allowed to drive  :driving: anymore, but i let him weld, cause hes pretty good...
booger weldz
we used generic cj/yj hanger for the front drop mount...
booger weldz
hes doing the finish grinding, im having a  :beer:
booger weldz
if anyne needs a set of shaackle jigs, let me know.  RUBICRAWLER let me have these and i promised to keep them alive in the SAS communuity...
booger weldz
Marketing
Looks good. I hope you let your son drive again soon. We need the next generation of drivers to be trained as young as possable!
90TOYPU
HELLO
84runner
 :headscratch: not  bad welding for a one year old. :thumbs: So what do you want for the jigs?
Marlin
The last time I saw a pitcure of welds that good--it turned out to be a great bondo job :smack:
Do you work at a body shop or are you really a booger welder?
Marlin
Brandon
purty, but you need gas so you don't get all that booger splatter ;)
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
booger weldz
#11
gas was cranked at 35 cfm cause it was sooooo windy---------->splatter....844runner, you can use the jigs anytime you need, im just passing them along for other axle swappers, mark langford gave them to me for the same purpose....
i dont do bodywork marlin, cant keep up with the dents in my truck after ever trip up the hill, but if you guys ever need a welder to help andy with all the fabbin:D:D:D
Marlin
So what brand of mig are you running?
Sure looks sweeeeeeee :biggthumpup:t
Andy's doing great, will let you know when he needs competition :yumyum:
booger weldz
im using a miller matic 175 and 75/25 gas, but the more i work outside the more im thinkin flux core(windy)...
as for andy, the work on the rear end of the double cab truck in the projects section looks awesome(im jealous) !
Marlin
Thanks, I will let Andy know in the morning. :bowdown: :bowdown:
Marlin
84runner
 8) Well gentlemen in the welding business you call that kind of weld laying dimes. 8) :thumbs:
booger weldz
#16
put my son to work on the bender
booger weldz
booger weldz
font springs are hung, axle is laying underneath and the shock hoops are welded in...
84runner
What part of california you from booger weldz?  Are you going to put those dumbells to use for something too?
