if I don't have to worry about emissions what can I get rid of
Started by kauaikid, October 11, 2006, 09:06:06 PM
kauaikid
I just bought a 84 toy and was putting on a weber when the mounting stud broke off in the intake manifold. :rivers:So my 1 hour job went south.  I pulled off the intake and tapped the hole.  How do I figure out what size helicoil to use for the stud?  But since I got all the vacum lines disonected I was wondering which ones are necessary and which ones can I get rid of. I want to toss all the emissions stuff. Any help would be sweet.
84 longbed, lc eng. top end kit, dual cases w/ 4.7 in rear, arb's front w/high pinion and rear with v6 diff., 5.29's w/ 35s, all-pro long travel 4" and much more
with a weber the only vacuum line you need  is the one to the distributor
throw the rest away
kauaikid
what about all the lines running into my intake. I know I gotta keep the fuel line and the coolant line but what about all the rest of the little vacum lines?
kauaikid
what about all this stuff? What do I need and what's for smog?
Plug and cap, plug and cap, plug and cap.  I have a weber on my 80 and only have 2 vaccuum lines:  vaccuum advance and brake booster.
CTENG in KS
Yeppers, you got an egr valve on that truck?  LC Engineering makes block off plates, you can ditch that junk too.
4inchToyotas
Take a look at my build and you can kinda see what vac lines you don't need. Ive only got the one to the dist and the PCV (not necessarilly a vac line) I can take more pics if you need.
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
kauaikid
4inchToyotas
Just looked at the picture I had on there  :talkingn: I'll take a couple of good ones when I get home from work. Might help with your other thread about the fuel pump and regulator too..But just FYI http://board.marlincrawler.com/index.php/topic,16722.80.html the picture I do have is on that page.
i kept  the charcoal can  with a line to it,  just because its the right thing to do
but all those metal tubes and junk  are  JUNK
kauaikid
kauaikid
is this you fuel pressure regulator?
4inchToyotas
4inchToyotas
Here's two showing my weber and the lac of vac....
kauaikid
that's great.  I went to autozone yesterday to buy a bosch fuel pump but when I opened the box it said carter.  I think I've heard some negative things about that one.  Anyway I just went with a redline from LC and while I was at it I convinced the wife to let me get the egr block off plates and a ceramic header.  I can't wait.  Thanks to everyone who helped me on this I greatly appreciate it.  Ken
CTENG in KS
I just put the block off plates on mine...for like $20 or whatever they are, they are REALLY nice billet parts.  New hardware and everything.  I was very impressed.
