22RTE swap and rebuild
Started by Bones, January 23, 2004, 07:35:46 AM
Bones
Got me a complete Turbo motor harness, computer, radiator, AFM for $200 in unknown condition (been sitting 2 years)
Plans are to replace the gaskets, water and oil pump as well as a good timing chain setup with metal guides. Also plan to have the head check out as well. I know to use a Toyota head gasket and ARP studs and I will. Not looking to go hog wild with it and go for max boost and swap turbos. Hoping the CT20 is still good.
Hoping to keep it under a grand so I have $800 left to spend. I can recoop a lot of that cost after I rebuild it and sell my current 22RE with 30K on full rebuild.
What else should I do while it's open (that's cheap to free) as well as have checked out by a pro.
Wish in one hand and.... :smack:
Knuckle Head Off Road
mr4x42u
I would pull the rods and main bearing and check them out..If they look good maybe throw ne  rings rods and main bearings in it..I'm sure once you got it apart you will notice if its going to be worth saving it or not or just do a total rebuild...You could sell it to me :santa: :smack:
Marlin
I would check the oil pump for wear first. The turbo uses a special oil pump with 30%? more volumne. I has been unable to locate these pumps except from the dealer. They are priceeeey. Check those plastic chain guides.
Look for cylinder head cracks between the smaller exhaust valve seat and the closest water port.
Marlin
Bones
Quote from: Marlin on January 25, 2004, 06:05:56 PM
Marlin
Thanks, The guides and oil pump will be replaced while I am in there. Head will get checked out for cracks or warping as well. More of less I will probably end up rebuilding it, since that's the way I am.  :hammer:
foxfab
#4
you can get turbo oil pumps from engnbldr.com as well as metal backed timing kits. I am running both in my 22RE. Also, if you do find that the head is bad, put an 85-87 22RE head on which will boost compression to 8.5:1 for a little more power. engnbldr. has these too. New castings, not rebuilt.
FOXFAB4x4.COM Custom body protection for you and your truck
NEUROC Team #87
Sponsored by Foxfab4x4 Budbuilt Rocklogic4x4 Rockstomper Stazworks
brainlessfool
84runner
Pull the head and see what kind of lip there is at the top of the cylinder, if there is one.  Then check for scoring in the cyclinders where the rings might stick. Then check the bearings for copper.  That is what I would look at.  Then if it all looks good I would still rering it just cuase its been sitting for 2 years, with a quick hone job.  And if you put it all together and it don't have that good of oil pressure you can put new bearings in just by pulling the pan
Marlin
#7
Quote from: foxfab on January 26, 2004, 10:27:08 AM
I have gotten aftermarket turbo oil pumps just to find out that it was a non turbo pump since they will both bolt to the timing cover.
A true turbo pump will have oversize gears and two oil vent holes in the housing.
I have always used the factory ASCO pumps.
I have also installed 85-95' 22R heads to bump the compression. It is a great upgrade!
Marlin
mr4x42u
engnbldr sells some great stuff and alot cheaper then most everywhere else..I would have to agree with marlin..If you don't know for sure why take a chance..Few buck now or alot more bucks later..Hey marlin,,how much difference does the head swap make compression wise? :beerchug:
Marlin
86-87' 22R-TE are listed at 7.5:1 CR and I think the smaller chamber non turbo head bumps the CR to 8.5:1?
Since all 85-95' heads are double drilled for both non turbo, and turbo exhaust mainafolds, it is a straight bolt on improvement. :idea:
Toyoballs
 :eyebrow: Thanks for the head info Marlin, I'm going to pull the head off of my 86 turbo truck - blowen head gasket :( - and I have a good 86 non turbo head I'll use if the original one is cracked. My local machinest said that he has a special boring tool to convert a non turbo head to a turbo head. But I like your idea MUCH better :greengrin:. Once it warms up around here I'll get back to work on it - fingers don't work outside in 15 deg. and my crawler is all apart in the heated shop :shake_head:
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
Marlin
I also have a boring attachment for my mill to reduce the compression raito, however, unless you live in a 120 degree desert, the non turbo head does great-just buy good fuel, and dont sit on the gas pedal everwhere you go and the engine will do great!
Marlin
Just a thought has anyone tried intercooling one of these?  With an intercooler you could open up all kinds of possibilities.  What are the odds that you could use water/alcohol injection?
mr4x42u
#13
I don't know about water or alcohol but alot of them are intercooled and its a pretty easy upgrade..T-bird inter coolers work great..There are alot of intercoolers you could use depending on where you want to mount it..I have seen them mounted up front of the rad and I mounted one for a friend on top of his motor and used a hood scoop to draw air through..Its a kick ass upgrade and pretty cheap to boot! :yupyup:FOSHO a must do..for what it cost how con one not do it?Intercoolers go cheap on e-bay..
Bones
Got a set of ARP head bolts and a metal head gasket from LC eng. coming for half price and yes....they are new :beerchug:
4RunnerRedneck
what is a  good price to pay for a Air to Water Innercooler
like the celica ones,?
$100.00 ?
or use the air to water innercooler I already have off:
the  top mount  TURBO RX-7 late 80's to early 90's maybe ?
1' sq x 1' sq maybe .in size.
Oh*** and how do i run water to the inner cooler.
and were do i buy one ?
Thanks to you all,  for any,  and all   HELP-FULL   INFO,
LOCKED Frt/Rear.109.to 1 .  63"chevys and 47"toy-rears in front . 9000's. full cage,9k/winch. Dual rear shackels,ARB's ,HI-PINION, V6.5.29's On-BOARD AIR TANKS TOO,H2O-Proof ROCK LIGHTS NO DOORS OR ROOF 4 now,ALL-PRO HYSTEER,ALLPRO-X-MBR. LONGSPLINE+C.V.= emergency rear d.shaft.
84runner
Big Mike would be a good guy to hit up about that price for the cooler.
Bones how did you get all that for half price I am in the market myself
Bones
Quote from: 84runner on February 01, 2004, 11:09:21 PM
Guy in CA sold his one owner turbo truck and has a ton of extra parts and a partial motor on Ebay. I got the above part before he put them on the net  :thumbs:
84runner
e_cliff
i loved the re head and intercooler when i had my turbo, i will do the same thing to my new daily driver 87 turbo sr5
cliff
jr9162
Quote from: Marlin on January 26, 2004, 10:28:46 PM
Marlin
Marlin - When building a 22R-E is there anything particularly desirable about using 22R-TE parts versus plain jane 22R-E stuff besides the turbo oil pump?
JR
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
Prismo
This site will help you for info, including intercooler
http://www.well.com/user/mosk/
While on this subject, does anyone know where I can find a wiring diagram for the 86 turbo motor & computer pin out online?
