Author Topic: shifter boot ideas?  (Read 1916 times)
BoMXtreme
  • Turtle Points: -24
  • Male Posts: 124
  • Member since Feb '04
  • Clean and stock cut short
shifter boot ideas?
« on: Sep 14, 2006, 02:16:45 PM »
I put a 2in body lift on my toy, which made the original shifter boot useless because of the raised body.  The throw of the trans and tcase shifter is too much foir the original boot, and therefore i need to find a new shifter boot that has enough flex to move with the shifters.  Was just wondering if anyone knows of any makes/models of cars/trucks that have a shifter boot that flexes and is roughly the same size as the original pickup boot so it can be easily mounted and made as much air/water tight as possible.  Thanks all.
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: shifter boot ideas?
« Reply #1 on: Sep 14, 2006, 02:25:03 PM »
i got a shifter boot at pepboys, it was a hurst one, it was quite large and worked, sure it wasnt completly watertight, but for daily driving, i never had a problem with it, the only time water ever came in was when i was frame deep in water... and it jsut came in around the base, im sure i could have sealed it off better and it wouldnt have leaked
BoMXtreme [OP]
  • Male Posts: 124
« Reply #2 on: Sep 14, 2006, 07:20:33 PM »
cool, thanks ill try it out
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #3 on: Sep 14, 2006, 11:41:27 PM »
I'd mess with yours a little more.  I'm still using my stock shift boots, and I've got a 3" body lift, so it can be done.  Not sure what the problem is?  when I first put in my duals, the tension of the shift boot would pull the crawl box into nuetral, but I cut the base of the shift boot, so instead of being one peice, each boot was its own individual peice.  not sure if that is how it came on your truck or not.
Pics?  why exactly wont' they work?  the boots on the third gen mount to the body, so they just get moved up a little when the lift is added.  I thought it was the same for all toys?
              -Ronald Reagan
yotabj
  • Turtle Points: -15
  • Male Posts: 116
  • Member since Feb '05
  • MAD FLEX YO!!!!
« Reply #4 on: Sep 15, 2006, 06:47:47 AM »
Why not just extend you Shifters and use your stock boots
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #5 on: Sep 15, 2006, 04:51:17 PM »
on my tacoma that had a bodylift i used a hairdryer to heat and stretch the boot.  took a while but eventually it worked.
BoMXtreme [OP]
  • Male Posts: 124
« Reply #6 on: Sep 15, 2006, 09:32:32 PM »
When i first did the lift, i probably shoul;d have just cut the boot in half, but i instead cut inside the actual boot where it contacts the shifter to free up for movement.  It worked ok, but still didnt allow for enough movement (pulled the tcase into neutral and wouldnt allow for 5th and rev).  And it also let in a lot of hot air from the engine.  I may go to the junkyard and find a boot that will fit and be flexy.  I just took a quick look at a junkyard after work, and there were some 2wd yota pickups, 90-95 that had some good shifter boots.  Might try one of them.  But any other advice would be great.  The hairdryer idea was a great one, and ill use that if i need to mess with the fit a little.
BoMXtreme [OP]
  • Male Posts: 124
« Reply #7 on: Sep 15, 2006, 09:35:21 PM »
Dont have a pepboys local, but is it the same as kragen or autozone?  I looked at kragen today and they didnt have any.  Thanks.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #8 on: Sep 16, 2006, 12:59:10 AM »
I wouldn't bother with an auto parts store boot, the ones at our local stores are about $20 a pop :yikes: I'd check on those third gen boots :yupyup: they should work out well. Pull of the mounting plates for them too, make it a clean mount when you put them in :thumbs:
              -Ronald Reagan
Last post Apr 14, 2004, 05:52:40 PM
by flipside_nv
Last post Jan 30, 2011, 04:19:08 PM
by pistolbob
Last post Sep 22, 2011, 07:18:19 PM
by desrodunes1
Last post Dec 07, 2011, 12:01:45 PM
by Crawler677
Last post Feb 29, 2016, 05:05:47 PM
by redneckcustoms13
